April. 15: v3.4.2
  • Feature: Add DXF support for Laser and CNC G-code Generator (#256)
  • Feature: Add import and export function for 3D printing configuration (#276)
  • Improvement: Fix copy/paste when using the console (#275)
  • Fix: Fix the bug of generated G-code file extension for CNC is wrong (#277)
  • Fix: Fix a SVG calculation error when unfolding arc (A) in (#282)
  • Fix: Fix a G-code parsing issue on Windows (#279)
  • Fix: Fix the bug that “marco” widget has only maximum capacity of 10 (#280)
  • Fix: Fix the bug that click camera capture will cause the software to crash (#281)
Snapmaker Luban for macOS
Snapmaker Luban for Windows 32-bit
Snapmaker Luban for Linux 64-bit
Option 1 (recommended)
Option 2
Snapmaker Luban for Linux 32-bit
Option 2
Hint: To start Snapmaker Luban on Linux, you need to:
  • Add your user to group dialout: sudo usermod -aG dialout [your username]
  • Start executable: snapmaker-luban (.deb version) or ./snapmaker-luban (compressed version)
