很高兴使用snapmaker的产品,最近看到网络上的输入整形(input shaper)技术,使用提前量消除震动影响,理论上既提高速度,又提高打印精度,应该是个不错的技术方向。
我的问题是
1)snapmaker artison硬件上有没有加速传感器之类的,从而在硬件上可以支持这一技术?如果没有,能不能后期diy支持?
2)luban软件有没有软件上的支持,修改gcode代码,修正提前量
You might not get that many responses while writing in your own language.
This is the translation by Google:
I am very happy to use snapmaker products. I recently saw the input shaper technology on the Internet. It uses advance to eliminate the impact of vibration. In theory, it can not only increase the speed but also improve the printing accuracy. It should be a good technical direction.
my question is
- Does the Snapmaker Artison hardware have an acceleration sensor or the like, so that the hardware can support this technology? If not, can you support DIY later?
- Does the Luban software have software support? Modify the gcode code and correct the advance amount.
thank u for the translation,but i still want the answer
You will need to wait. Normally Snapmaker support does not check the forum very frequently
