Snapmaker 2.0 Enclose - Support Fan Controll Defect
Hi guys,
during replacing a broken fan in my enclose, I made a shortcut on the fan wires (gnd to 24V) and therefore a transitor blow up. All other units (light, door controll) are still working so I assume, that this is the only defect.
I would give repairing a change, if I would know, what kind of SOT23 transistor I would need to use. Can anybody support me there?
Thanks in advance,
jomjol
If you have Board rev
SPD-0005 V2.0
aswell, its the same type as Q3 based on the pic i took from my controller a while ago.
What is this board called ? The part number SPD-0005 doesnt seem searchable online, I blew mine up . Thanks.
Probably not useful to you anymore, but my enclosure exhaust fan stopped working and have traced it back to one of the mosfet transistors, they are labeled 0102 and supply the 24v to the fan. I’ve sourced a replacement from aliexpress, AO3400A. Once it’s arrived and I’ve installed it, I’ll update this thread in case it’s useful to anyone else.
https://www.aliexpress.com/item/1005006116828250.html should do the trick - AO3400A
This seller in eBay has what you are looking for. eBay item number:358867188399
