Sidecar 16 color MMU for U1
I’ll just leave this here:
OK? There are at least 10 different open source mmu units out there, not sure why you left this here? Here’s a good video showing some of them https://youtu.be/rBXQqZq790M?is=R859xFmuGketBo1G
Sure should have said more to it. I basically just wanted to continue on my earlier argument and show how it could also be done, open sourced, get help from the community, and tinkerer can built their own. This does not mean you can not sell Kits or even fully assembled ones, which would sell the same amount in my opinion since there still lots of people who don’t want to diy. Anyways just wanted to elaborate on my earlier point to not seem like someone who just wants to make your project bad or something, actually it’s the opposite, I think you could vastly profit from making it open source. In the end I would love if it’s open source and still produce a lot of money and don’t get buried because of the closed source nature and people moving on to better open source projects (see Swapmod). But this was the last post from me now I don’t want to be too annoying :smiley:
As announced at the Snapmaker 10 year anniversary party, it will be open source.
Oh okay, than sorry for my gobbledygook. I’ll see myself out ! :sweat_smile:
where can we see the annoucement? is there a video, a article?
most antecipated project for me, it`s sidecar! you rock!
I’m not sure if it was/will be broadcast, it was at their private 10 year anniversary party at their HQ in Shenzhen.
how can we make this or buy this i would happily buy this
I would pay $1,000 for this right now.Make that happen, please! Make it enclosed with humidity and temperature control.
Any ETA when you think you’ll bring this to market? I’m assuming your working a deal with Snapmaker to make it an officially supported product. Any information you can share would be appreciated. Thank you
Additionally, what is the purge volume consumed for each module? I have a due date in mind because I’m tempted by the Bambu Lab Vortex and the Core One Index, but I’d rather buy your project since it’s open source.
I notice that creality’s new mmu the cfs-c which incorporates a filament cutter external behind the printer. They seem to do tip forming then retract and then cut the end off which falls into a bin. Would there be an advantage incorporating something like this into your setup? Having no knowledge about tip forming, how difficult is it to get right and reliable?
Tip forming is to (try to) ensure the tip does not form into a blob which then jams in the tubes. Having the cutter back down the tube seems a bit pointless.
The problem is lack of closed-loop control. Whatever formula is used to form the tip, it has to work blind and with all varieties of filament (not forgetting there may be contamination from previous filaments in the hot-end).
Pretty sure I need more cereal boxes now.
This is incredible. I have been thinking about this since I got my U1 in January to go alongside my X1C+AMS. With it being open source firmware it has always seemed like a matter of time thing and I’ve been slowly acquiring parts to build my own idea of this. Glad I found this before getting too far into it, I’d definitely buy it if/when it’s available. If you open source it I’ll donate and contribute to it!
Yes I know I technically necro’d this thread but this project cannot die out!
Every thread of worth requires a prod occasionally, if for nothing else than to bring it to the top of the list again.
@Sidecar I LOVE this project, unfortunately it went a bit quite here… Is it still in development? I know, “good things require their time” (german saying), but it would be very kind, if we got an update or current status of the project. I am desperately waiting for it. Since I print very different type of things I am constantly swapping spools…
I know it’s been a long time since I posted an update. I’ve been extremely busy with my normal work, so Sidecar hasn’t gotten much attention lately.
While it’s been sitting, the printer market and the U1 ecosystem have moved incredibly fast. Several new multi-tool and hotend-changing printers are in development, which makes complicated MMU systems less appealing than they were when I started Sidecar. Snapmaker is also working on its own MMU for the U1.
Open-source projects like MultiACE and AFC Lite now cover much of the extra-material and color functionality using existing MMU hardware. They’re also being integrated into the PAXX firmware and slicer workflow, so there’s less reason for me to keep developing an entirely separate system that duplicates much of what they already do.
That doesn’t mean Sidecar was completely replaced. It still has features those projects don’t, including active QuickPurge hardware and load-cell spool weighing. But I don’t think there’s enough demand left to justify manufacturing the complete Sidecar system as originally planned.
Because of that, I’ve decided to release Sidecar as an open-source project. I’ll be releasing the CAD, firmware, code and other useful project files so the work doesn’t just sit abandoned. I don’t have a release date yet because I need to organize everything and make sure the files are understandable and usable outside of my own development setup.
A couple of related projects are still moving forward:
  • UMMU is still in the works. Its purpose is to let U1 owners use different existing MMU systems instead of being limited to ACE hardware. The scope and initial compatibility list still need to be worked out, but I haven’t abandoned it.
  • I’m also considering turning Sidecar’s QuickPurge system into a standalone hardware kit for projects like MultiACE. That could preserve one of Sidecar’s biggest advantages without requiring the entire Sidecar system.
I’ll also be reaching out to the developers of the existing open-source projects to see where Sidecar’s work might fit instead of building another completely separate ecosystem.
Thanks to everyone who’s continued following the project and asking for updates. The original commercial product may no longer make sense, but I’d rather release the work and let the community use it than leave hundreds of hours of development sitting on a hard drive.
First of all, man, I want to thank you for giving us a glimpse of what you made possible. You were probably the first person to grasp what four nozzles on a Tool Changer could unlock when you eventually have more subdivisions for it. Your idea for the Quick Purge was exceptional, and I am sure there would be an audience for you to sell it to. Maybe not a huge audience, since it’s probably an expensive project to execute. But if we’re being completely honest, your project is on a level way above anything we can think of in multi-material systems today, whether it’s MS, Multi-Ace, or Ace Pro. Honestly, your project is a work of art in product development. Congratulations.
Second, man, since you aren’t going to keep developing it, congratulations on releasing this work of art, which isn’t even just code, so the community can keep implementing, developing, and improving it. Kudos to you for that attitude. And man, it would be spectacular if you could work together with DK71 from Multi-Ace. I can only imagine the amount of awesome stuff you two could do for the ecosystem.
Either way, man, we’re here for you. Whatever you need, you have our support. I think you’re one of a kind, and you make a huge difference in the 3D printing community. Thanks a lot, man. We’ve got your back.
I also want to sincerely thank you. I believed in your project from the very beginning and always hoped it would become available soon. Deciding to make it open source was the greatest gift you could have given the U1 community.
Please let me know how I can thank you financially. Your work has taken a lot of time.
