We dont have the touchscreen software and snapmaker made only the controller firmware open source.
I guess there is no chance…
Try opening a support request and we will see, if you share
Yeah I’m not sure if there’s a solution with Luban, but with octo print if you have a touch screen, there;s 2 plugins you can add that makes the icons larger so touch control is easier.
I just wanted to see if anyones tried specifically with luban
Alternatively to the touchscreen it would be possible to use only luban (in most cases but you would not be able to easily calibrate your machine, etc…).
