Does anyone know the size & material of the Artisan’s filament tubes? One of mine got a chink midway through the tubing. Thanks!
Bowden tubes are usually PTFE… not sure about the diameter unfortunately…
Standard OD for 1.75mm filament. I believe the ID is 2mm. Not sure on length but 1m per side should be sufficient.
Something like this should work: Amazon.com: PTFE Teflon tubing 5ft- 2mm ID X 4mm OD for 1.75 Filament Bowden 3D Printer -Allen Tech PTFE Teflon Tube : Industrial & Scientific
