Recently put my 10W back on and had to dial it in with the new square I use for repeatable origins. Accidentally ran a fill instead of just a score and… huh, the edges were massively blurry kinda like my offsets were absolutely horrible. Some more testing and I figured out, the laser isn’t actually turning off during the overscan sections! Something in the background changed on the firmware. If you’ve been dealing with fuzzy/blurry edges, this might be your fix as well.
Here’s an image from testing (one square goes in the opposite direction because I rotated the stock).
Notice on the red dot one, all the lines go outside the box, no matter the offset, they look fairly even too! So I made a massive offset and changed the setting “Use G0 moves for overscan” as seen below. I also added the below code to the start gcode box.
G0 S0
G1 S0
Since Marlin saves the power for G0
and G1
separately, if there’s a different value it can just run as well, as Lightburn expects any G0
line to be off (like every other laser does). Those two lines ensure they’re set to 0 power.
This gave me green dot square, success! So I put my offset back to where it was, obtained blue dot square. Perfection.
So yeah, TL;DR, enable Use G0 moves for overscan
and put the two lines above in your start, and end gcode (just for safety on the end).
EDIT: Make sure you’re using the “GRBL-M3” device profile and not the standard “GRBL” or “GRBL-LPC”. I had a recent project go awry and figured this out because I had selected the wrong one.
It seems there’s some form of bug that when there’s just a single thing to laser in a single scan line, say a | (there’s no laser on/off for a new object), it just… doesn’t. Whereas if there’s multiple items in the same scan line, say a simple U (where the laser turns on for one side, then turns off for the center, then back on for the other side, it comes out fine. I figured this out with a fancy ‘f’ and then did an independent test where all I did was change between the two devices.
Results of my tests are… striking. Sorry for the poor angle, it was a mirror and was being a pain to capture. The lower left one was using “GRBL” as the device, the upper right one was using “GRBL-M3” as the device.
It really shows my bad explanation from above. The center, where it only comes on once for the center of the ‘f’ is completely not there, whereas where it has to turn off and on for the fancy swoops is fine. Why this happens, I have absolutely no clue.
TL:DR2; Make sure to use GRBL-M3
as the device if you’re getting missing lines and skips.
