Being a Newbie, to 3D printing, I started with PLA and PLA+…and feel pretty comfortable with printing with those. PETG, even though I seem to have read every article and tried many settings, I still get blobs, but only on vertical surfaces.
I have been trying different settings with a very simple test model
I have tried temperature towers, and 230 or 240 seem to give the best results - I have tried the Snapmaker PETG, Sunlu and eSun filaments (all dried to 50’C in a dryer)
I have no issues with the initial layer going down…that looks beautiful (with a Z offset of +0.1). I also have no issue of it coming off the bed after print.
I am using Luban, and the vertical wall (back and front is seen as an outer wall)
I have tried increasing print speeds from 20, up to 55mm/s
I have tried decreasing flow rates from 100% to 80%
I have tried increasing travel speeds, up to 110mm/s
I have tried different temps from 255’C down to 220’C
I have tried retract at layer change
I have tried Retract distance from 3 to 7mm
I have tried Retract speed from 30 to 80mm/s
I have tried enabling Z-hop from 0.5 to 2mm
Fan at 30%-100%
and combinations of all of the above.
Interesting that Snapmaker’s own spec says to print PETG at 40-100mm/s, but reading on here, that seems fast)
The slower speeds (15-25) definitely give very fine stringing (and I mean very fine), but if I read correctly, then PETG will always seem to do this. Faster print speeds seems to reduce this, but not the blobbing
The base and the side of my test model are 100% perfectly smooth - no issues there, whatsoever
Anyone help me out of my misery here ?
