Persistent Toolhead Swapping Anomaly Counts
Toolhead Swapping Anomaly counts should be cumulative (user resettable) and accessible on a report screen in Settings > Maintenance (not just at the end of a print). Personally, I would also like to see per-toolhead retry and failed retry counts, and failed retry counts as a percentage of toolhead pick-ups.
This would enable experienced users to monitor the performance of the pogo pins and take preventative measures in a timely fashion.
Isn’t the “Toolhead Swapper Anomaly” message at the end of a print already doing that (causing user panic)? Getting detailed stats and putting them in context should/might alleviate some of that panic.
I wasn’t panicking, but I was concerned that I could see retries occurring (at the machine and in the Fluidd console) but was not getting anomaly reports (because I did not understand what counts as an anomaly). Proper stats would have resolved that.
Persistent (rather than per-print) stats are necessary for maintenance interventions.
