Online openscad viewer and editor
Hej Guys, I have created an openscad viewer and editor. It’s a webapp but everything “runs” on your computer. You can save and upload you own openscad code, edit and save. But it will still be saved locally (cokies).
I will work on making the editor more configurable and maybe use the same layout as openscad but probably not. will see.
Release v0.3.0 with a new code editor. It now have syntax highlighting, autocomplete, line numbers, search and replace, and some ready-to-use OpenSCAD code snippets.
I have also made some improvements to the mobile layout. You can now keep the 3D viewer visible while scrolling through the parameters.
Release v0.4.0 has now undo/ redo, two different orca color 3mf exports. Now you can export an import openscad models with colors into snap orca directly.
Opensource of course :slight_smile:
