This is first. Any idea what causes this? This was printed with fast settings.
Secondly whats going on with this benchy? This was printed with strong and precise.
The first photo: I have no idea what you’re referring to. What exactly is wrong? Did your print split up? If so, most likely you had a temporary nozzle clog.
Benchy: Would guess you’re printing too hot, but I may be wrong. Perhaps your nozzle needs a good cleaning.
I find these pages helpful to analyze problems: Print Quality Guide | Simplify3D Software
Yeah, it split
I don’t think it’s a nozzle clog as others have split with the fast setting. My first benchy split as well. They don’t split when I use strong and precise but that takes a lot longer. I’m trying to dial in my settings.
I’ll take a look at that guide you posted though.
If you are using the single extruder, calibrate your E-Steps: Summary: Extruder calibration a must
I am using a single extruder so I’ll take a look at that too.
I did just order the dual extruder.
Does this apply to that as well?
For me, the dual extruder was dead-on with factory settings, while the single extruder was underextruding and needed E-steps-adjustment.
