My First Experience with the Snapmaker U1 High-Flow Hotends – Up to 500 mm/s and Excellent Print Quality
@Zoe_M Again thank you very much for the High Flow Hotends :+1::heart: And here my promised test experience.
I’ve recently installed two of the new Snapmaker × Phaetus Liber High-Flow Hotends in my Snapmaker U1, and I’d like to share my first experiences and results.
For this test, I wanted to use a model that could actually take advantage of the increased flow rate. After all, a high-flow hotend doesn’t necessarily make every print faster. The model needs sufficiently long extrusion paths to allow the printer to reach and maintain higher speeds.
Choosing the Right Model
I selected the “echo · tray” model from Snapmaker Space:
I printed the inlet part of the tray, which seemed particularly suitable for this test because it has relatively long, straight extrusion paths and only a few curves.
This should allow the High-Flow Hotend to demonstrate its advantages much better than a small, detailed model with lots of short movements and frequent direction changes.
Filament and Calibration
For the test, I used SUNLU PLA 2.0+ High Speed.
Before printing, I calibrated the filament using the calibration tools already included in Snapmaker Orca (SnOrca).
I performed the calibrations in the following order:
  1. Flow Rate – Pass 1
  2. Pressure Advance
  3. Max Flow Rate – Max Volumetric Rate
I created a custom SUNLU filament profile based on the existing Snapmaker SnapSpeed PLA profile and updated the relevant parameters with the results of my calibrations.
Interestingly, the SUNLU filament produced good results at volumetric flow rates of up to 50 mm³/s during calibration.
I was quite surprised by this result.
To leave a little safety margin, I decided to set the Max Volumetric Speed to 45 mm³/s in my filament profile instead of pushing it to the maximum value observed during testing.
Installing and Configuring the High-Flow Hotends
For my initial tests, I only replaced the standard hotends in Toolheads 3 and 4. Toolheads 1 and 2 still use the original standard hotends.
One important detail after installing the new hotends is that the printer needs to know which toolheads are equipped with High-Flow Hotends.
On the U1 touchscreen, this can be configured under:
Settings → Maintenance → Toolhead Info
Make sure to select the correct hotend type for each toolhead.
After that, you need to synchronize the information in Snapmaker Orca by using the Synchronize Nozzle Informationfunction in the printer settings.
Otherwise, the slicer may not recognize that the corresponding toolheads are equipped with High-Flow Hotends.
Another important detail: Use the default 0.20 mm Standard process profile.
According to Snapmaker, this is currently the only process profile that has been fully calibrated and validated for the High-Flow Hotends.
Print Settings – Nothing Else Changed
Apart from my calibrated filament settings and the High-Flow Hotend configuration, I did not change any other print settings.
I used the standard 0.20 mm Standard process profile with Snapmaker’s default High Speed settings.
As you can see in the attached screenshots, the maximum printing speed in the Speed tab is set to 500 / 600 mm/s.
I deliberately left these settings untouched because I wanted to see what the U1 could achieve using Snapmaker’s existing High-Flow configuration, without manually optimizing the process profile for this particular model.
Important: Check Speed and Flow in the Slicer Preview!
One thing I strongly recommend is to carefully check the Preview after slicing, especially when using the High-Flow Hotends for the first time.
In Snapmaker Orca, switch the preview visualization between Speed and Flow.
These views use different colors to show exactly where the printer will reach certain printing speeds and volumetric flow rates.
It’s also worth using the layer slider to go through the individual layers and see how these values change throughout the print.
This is actually how I discovered that I had initially forgotten to synchronize the nozzle information in Snapmaker Orca after configuring the High-Flow Hotends on the printer.
As a result, the slicer was still using the limitations of the standard hotends instead of the High-Flow Hotends, even though the new hotends were already installed.
Without checking the Speed and Flow preview, I probably wouldn’t have noticed this immediately.
After synchronizing the nozzle information and slicing the model again, the preview reflected the updated High-Flow configuration.
My recommendation: Don’t just check the estimated print time after slicing. Always inspect the Speed and Flow visualization, and go through the layers with the slider.
This is a very useful way to verify that the High-Flow settings are actually being applied and to see which parts of your model can benefit from the higher speeds and volumetric flow rates.
I’ve also included screenshots of both preview modes to illustrate this.
Actual Printing Speed
The recordings from the Fluidd interface show that the printer repeatedly reaches 500 mm/s during printing.
Of course, it doesn’t maintain this speed throughout the entire print.
The actual speed depends heavily on the geometry of the printed part.
On longer straight sections, the printer has enough distance to accelerate to 500 mm/s. On shorter paths, it needs to slow down again before reaching the end of the movement.
Curves, changes in direction, and outer walls also require lower speeds.
This is exactly why I chose this particular model for the test.
And watching the U1 repeatedly reach 500 mm/s while printing is quite impressive!
Estimated vs. Actual Print Time
Here’s another interesting result:
Print Time
Snapmaker Orca estimate 1 h 50 min
Actual printing time 1 h 44 min
The print actually finished 6 minutes faster than the slicer’s estimate, approximately 5.5% less time than predicted.
I wasn’t expecting that, especially considering how fast the printer was already running.
Print Quality – The Most Impressive Part
What impressed me the most wasn’t just the speed, but the actual print quality.
Despite the extremely high printing speeds and the 45 mm³/s maximum volumetric flow setting, the finished part looks excellent.
There is a very small amount of extremely fine stringing, but apart from that, I really have nothing to complain about.
The overall result is remarkably clean, especially considering the speeds involved.
I’ve attached photos of the finished print and videos showing the printing process and the actual speeds reported by Fluidd, so you can judge the results for yourself.
My Conclusion
For my first real-world test, I’m genuinely impressed with the Snapmaker × Phaetus Liber High-Flow Hotends.
A few things stood out to me:
  • The SUNLU PLA 2.0+ High Speed filament performed very well after calibration, even at surprisingly high volumetric flow rates.
  • Using 45 mm³/s as a conservative maximum worked very well in this test.
  • The printer repeatedly reached the configured maximum printing speed of 500 mm/s.
  • The actual print time was even shorter than Snapmaker Orca’s estimate.
  • Most importantly, the print quality remained excellent despite the high speed.
Of course, this doesn’t mean that every model will benefit equally from the High-Flow Hotends. Models with lots of fine details, tight curves, and short extrusion paths will naturally see smaller advantages.
But for larger models with long, continuous extrusion paths, the potential is definitely there.
One thing I want to emphasize: I didn’t need to tweak any of Snapmaker’s default speed settings to achieve these results. I only calibrated the filament, configured the High-Flow Hotends correctly, and used the existing 0.20 mm Standard profile.
For a first test, that’s a pretty convincing result.
I’m looking forward to testing more models and materials to see how far these hotends can go.
Videos
Very good quality. I bought the high-flow ones last week; I hope they arrive this coming week.
It is generally recommended to set the max VFR to 80% of the rate at which the calibration test starts to show gaps or extruder clicks. This is well documented, you don’t need to guess your own fudge factor.
Thanks for your message and recommendation!
I didn’t just guess the 45 mm³/s value. I calculated it based on the recommendation in the Orca Wiki, which states:
“You may want to reduce the flow by 10%-20% (or even further) to ensure print quality/strength.”
So I decided to go with a 10% reduction from the original 50 mm³/s.
Orca Wiki
Thank you for this incredibly detailed product review! :grinning_face:
I’ll relocate your post and the following comments to a separate topic, so it can be a useful reference for other high-flow hotend users.
Best regards.
