Melt3D — clay-like SDF CAD that exports 4-toolhead multi-material 3MF for the U1
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
07egta
Project name
Melt3D — clay-like SDF CAD with multi-material 3MF export for the Snapmaker U1
Project URL
Project cover
Project Category
3D Model Editor
Project Summary
Melt3D is a free, open-source 3D modeller written in Rust (egui/wgpu). Shapes are signed distance fields (SDFs), so they melt into each other like clay: smooth blends, carving, sketch-and-extrude, curves and pipes. A built-in precise-solid mode (SolidCraft mode) adds constrained sketches and parametric history for parts that need exact dimensions. Melt3D already exports STL / 3MF / OBJ / PLY / GLB with print checks.
The idea for the U1: melted SDF shapes have no clean seams, so it’s hard to turn them into multi-material prints today. I want Melt3D to be the first editor where you design with the U1’s four toolheads in mind:
  • Material per body: assign each body/region to a toolhead (T1–T4). Where bodies melt together, the blend zone goes to one side, either chosen by the user or by nearest-field rule, so each toolhead gets a watertight mesh with no overlaps.
  • U1-ready 3MF: write a multi-object 3MF with the extruder assignment and filament colors already set, and the U1’s 270 x 270 mm bed, so it opens in Snapmaker Orca ready to slice. No manual re-painting.
  • Material-aware design: e.g. a soft TPU grip that melts into a rigid PLA core, or PLA + soluble support placed only where the SDF geometry overhangs.
  • AI / MCP control: Melt3D can be driven through MCP, so an AI assistant can build or edit a model (“make the handle TPU, the body PLA, put my name in white”) and export the U1 file. (Already in the public repo: meltcad --mcp exposes two tools, melt3d_run and melt3d_view.)
Why I need a U1: the hard parts (purge/wipe volumes at melted boundaries, how thin a blend region can be before the toolhead change makes it fail, adhesion between materials) can only be checked on real four-head hardware. I don’t own a U1 or any multi-toolhead printer — my printers are a Flashforge Creator 5 and an Anycubic A1 mini. I’ve also learned the hard way that a model can look fine on screen and still export to STL/3MF with holes or bad faces, so I’ve already spent a lot of time on save-corruption guards, auto-recovery and mesh checks; the same checks will gate every per-toolhead mesh.
Plan (idea stage → verified): my development lesson so far is “make what exists work perfectly before adding more”, so the plan starts with stability and keeps scope small:
  1. Weeks 1–2: per-body toolhead assignment (T1–T4) + multi-object 3MF export; test that it opens in Snapmaker Orca. Single-material STL/3MF export must keep working (regression check before every build).
  2. Weeks 3–4: blend-zone splitting rule + watertight/mesh checks per toolhead; publish a first set of sample files.
  3. Weeks 5–6: fix what breaks, Windows build/packaging through GitHub Actions, short docs draft. Until the U1 arrives I can only test single-material printing on my Creator 5 / A1 mini.
  4. After the U1 arrives: print-test matrix (blend width × material pair); publish photos, logs and settings in this thread.
  5. Docs: a user guide “Design for U1 in Melt3D” + exampl
Open Source Status
Open Source
Please specify the open source license used by this project
MIT OR Apache-2.0
Cash Fund or U1 Hardware Sponsorship
Originality
Improvement / optimization based on an existing project
If based on an existing project — your independent contribution
Melt3D is a derivative of SolidCraft, an open-source CAD (GitHub - tangency-labs/solidcraft: SolidCraft: an open-source parametric 3D CAD application built in pure Rust. Desktop, web, and automation through MCP. · GitHub, MIT OR Apache-2.0). Melt3D includes SolidCraft’s source code: crates/, vendor/ and xtask/ are SolidCraft code, and its precise-solid mode (“SolidCraft mode”) is SolidCraft’s constrained-sketch/parametric modelling. Melt3D is independent and not affiliated with or endorsed by the SolidCraft authors.
My own work (mainly in apps/meltcad/):
  • The SDF “melt” modeller: smooth blending, carving, sketch → extrude, curves/pipes, animation, materials
  • Importing SolidCraft solids into the melt workspace
  • Export with 3D-print checks (STL / 3MF / OBJ / PLY / GLB)
  • MCP / AI control (meltcad --mcp, tools melt3d_run / melt3d_view; built for Melt3D, in the public repo)
  • How it’s built: I direct, decide and verify; the implementation is written with AI through GitHub Issues/PRs. I’m open about this.
New for this competition (planned, not built yet): per-body toolhead assignment, blend-zone splitting into watertight per-material meshes, U1-ready multi-material 3MF export, and print tests on a U1.
Is it a paid project?
No
