I have some question. Printer is running good. Wanted to change a bit XY under M92 because my xzy Cube has 20.20mm I wanted to change this. There for i checked with M503 my Settings. And found M92 X160 Y160 Z400 E212
Why does X Y have just 160 Steps? I have the A350T is there XY different?
Any post I read is X400 Y400 and Z400.
Can someone explain to me why I have 160?
Please excuse my English, I wrote it quick on my mobilphone without Google
thanks for the quick help. the exact dimension was not 20.2 for all axes. The results are between 19.99 and 20.25. But I will test that with the 30mm cube whether the deviations in relation remain the same. thats a nice hint.
It was important to me why there are only 160 at X and Y. But I got the information why. It’s all OK. thank you
E212 is usually way off. I would calibrate that first. Plus you never adjust x, y, or z steps based on a printed cube. you measure the actual travel of the axis. It’s very simple to do of you have a digital or dial caliper.
John
Be mindful of backlash or you’re guaranteed to measure wrong. Cue it up in the direction of travel. Although the backlash “should” be negotiable if everything else is functional. If it’s like my X axis was with 0.12mm of backlash then that would significantly throw off the measurement.
