I do not understand the units for laser dwell time.
My Luban 3.8 UI shows Dwell Time as “mm/min” (screenshot attached), and posts on the forum imply that reducing the dwell time should lighten the burned image.
As I see it, as you reduce the “mm/min”, then it should take longer to cover the same area… thus actually increase the time per pixel. Am I missing something?
the “definitive guide for laser cutting and engraving” has dwell time as “ms/dot”.
link here
This seems to be more intuitive as a unit of measuring dwell time (per pixel), but I am not sure what to do about the UI.
Any ideas would be appreciated.
Thanks
