Luban CNC Preview
I am quite new to this but if I import an svg file from lets say Inkscape. I then try and preview … the file disappears from the screen. What am I doing wrong.
If I create the text lets say in Luban … it shows the preview fine but only for that text.
Is it text that disappears? Or other artwork?
I’ve had this happen with inkscape files.
You have to convert the text to paths. Select the text and then under “Path” menu select “Convert object to path”
Make sure you’re exporting as simple svg (not inkscape svg)
I’m having the same issue - exported an .svg from Photoshop layer. It opens and edits in Luban just fine. But when I hit Process, the image disappears.
(I tried to attach the file. Just shows as blank when I save edit)
figure
You’re not allowed to upload images yet.
You’ll need to use an offsite host to share.
