Lens replacement for the 40W Laser
Hi guys,
has anyone some details about the lens for the 40W module please?
It has M15 and the lens itself has a diameter of 9.5mm (lens capuslation 14mm and it is 4.8mm above thread…
Would be great to get a link for a similar diode laser lens.
While I’m not sure if it’ll help (if the lens is indeed 9.5) as the lowest this place goes is 12, but I get lenses for my XTool from ess.
Finding a place that sells watch crystals the diameter you need will be your best/cheapest option if you can get the lens itself out.
@Skreelink Thank you, but I live in Europe.However, this helps me already. As it will be much easier if it is a crystal flat glas without any special focus, angle or whatever.
I will try to find a glas lens with collimation. Let me know, if someone here is faster in finding a proper one :slight_smile:
