- Done By one of our users Joseph Lee Rich
- Post:
- After several failed attempts; I got my first big laser test photo done.
- Done By one of our users 張益誠
- Post:
- ALL test pass!
Laser CNC and FDM is great in snapmaker.
But somehting can be better if they change.
1.FDM PLA caliber is bigger than 1.75mm.
It make sometime the Wire can not be pass to nozzle.
In these test I use the wire in 1.68mm
(some wire default this size and write this 1.75mm)
And also the wire from snapmaker often stuck too.
2.FDM doesn’t have any function about send wire.
This mean you can not check wire is stuck beforce you open.In other product you can got this function(send 1,5,10mm with wire)
3.Laser’s default power don’t need over 70%.
Maybe software can set the defult power like 30% or 25%.
It’s can save the wood when user test lol.
全部功能測試完畢,
CNC和雷射以及FDM的表現是傑出的,
為工作團隊致上敬意。
不過有些小問題,未來改善的話會更好。
1.FDM的口徑是1.75mm,但輸入管內鐵定超過,
這導致了料會在半途中卡住,像是官方料就卡住好幾次,更別提台灣多數線材大概都在1.65~1.69之間,卡的次數比官方線材更多
2.官方軟體缺乏送料測試功能,結果導致送料出問題時,我們只能拆開來看,非常花時間也很沒意義。
3.雷射初始功率設定太高了,不需要100%,只要25%或35%就可以進行木頭的雕刻了,希望預設值不要這麼高
I just try this on wood PLA and the wood.
It has a great work.
- ALL test pass!
