Has any of you tried to laser “engrave” a micro fibre towel?
If so do you have parameters to share?
(Just a random picture of google how it could look)
I did not try that, but interested in knowing if it worked for you and parameters used.
I just tried with 10% (of 10W), 0.15 mm Line, 3000 mm/min work speed - turned out „o.k.“ but I think a little less power would be good or that you use points instead of lines because the outer contours are part wise visible from the other side (I tried it on a micro fibre towel from Decathlon)
