Kromacut: turn images into multicolor layered 3D prints (Phase 2 update)
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
vycdev
Project name
Kromacut
Project URL
Project cover
Project Category
Software
Project Summary
Kromacut turns an image into a multicolor layered 3D print. It’s a free, open-source web and desktop app (Windows, macOS, Linux) that reduces an image to a palette, plans which filaments to stack in each area, previews the result in 3D and exports slicer-ready STL or 3MF files.
What it does differently
  • It models light through filament. Auto-paint predicts the color of thin filament stacks from each filament’s measured Hiding Distance, blending in linear light, and scores candidates by CIEDE2000 color error at real printable layer heights.
  • It learns from prints you measure. Printable HD wedges, Stack Matrix boards and Palette Proofs turn real test prints into measured data. Every predicted color shows what it’s based on: a measurement, interpolation, a fit, or simulation only.
  • It searches for the best stack. Five effort tiers, from Fast to Exact, search filament stacks for each image color with fixed seeds, so results are reproducible. It can also keep distinct image colors distinct within a set color-error limit.
  • Its geometry is slicer-safe. Regression tests check meshes for open edges, T-junctions, flipped faces and duplicate triangles. 3MF exports keep one object per physical layer and use your real filament colors.
  • Flat Paint prints full-color flat artwork with several colors in the same layer, face up or face down.
Why it fits the U1
Kromacut’s color stacks and Flat Paint artwork need many filament changes, often several within one layer. On a single-nozzle printer every change costs purge waste and time; the U1’s four toolheads make these prints practical. For Phase 2 I’m adding a U1 export target that assigns filaments to the four toolheads and exports a 3MF project ready for Snapmaker Orca, plus toolchanger-aware planning (details below).
Kromacut has 300+ GitHub stars, about 3,000 desktop downloads, and around 1,500 visits a month from Google Search.
Open Source Status
Open Source
Please specify the open source license used by this project
AGPL-3.0
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Improvement / optimization based on an existing project
If based on an existing project — your independent contribution
This is an update to my own project, Kromacut which is one of the winners of the Phase 1 SnapMaker Innovation Fund. All Kromacut code is my own work, published under AGPL-3.0.
Released since the Phase 1 deadline (Sep 7, 2026): v4.0.0 (Sep 10), v4.1.0 (Sep 26) and v4.2.0 (Oct 19). Full notes: Kromacut/CHANGELOG.md at main · vycdev/Kromacut · GitHub
  • New optical model: replaced backlit TD with frontlit Hiding Distance, blending in linear light with substrate-aware estimates.
  • Stack Matrix calibration: print up to 64-layer filament recipes on one board, photograph it, and align a grid to measure every recipe’s color. Broader fits are used only when they improve held-out measurements.
  • Palette Proofs: print candidate stacks for a specific image, record the closest match, and feed the result back into matching.
  • Prediction confidence: each printable color reports whether it comes from measurements, interpolation, fitting or simulation.
  • New search: Fast to Exact effort tiers with deterministic seeds, plus an option to preserve color separation under a hard color-error limit.
  • Printability checks: preview detail at your real line width, and optionally remove isolated color specks that can’t print cleanly.
  • Geometry: face-up Flat Paint without a clear carrier, four smoothing strengths (None to Aggressive) that also work with Flat Paint, and fixes for watertight smooth 3MF exports.
  • Validation tools: offline replay and held-out tests that compare predictions against photographed prints, plus deterministic regression tests for stacks, exports and mesh topology.
  • App: 12 languages, desktop file associations for profiles and palettes, and Linux delta updates.
Planned for Phase 2 (before Dec 23): Snapmaker U1 support
  1. U1 export target. Assign Kromacut’s physical filaments to the U1’s four toolheads and export a 3MF project with toolhead assignments and recommended settings, so it opens in Snapmaker Orca ready to slice.
  2. Toolchanger-aware planning. Let Auto-paint and Flat Paint plan around four loaded toolheads. Same-layer multicolor prints need many color changes per layer, which a toolchanger handles with far less purge waste than a single-nozzle system.
  3. U1 guide and validation. A U1 guide in Kromacut’s docs, plus validation prints with photos and measured results. I don’t own a U1 yet, so I’ll test with U1 owners from the community until I obtain one.
Is it a paid project?
No
Videos
Image to 3D print tutorial
Project introduction
Showcase
Six prints from the showcase on https://kromacut.com. Each one shows the Kromacut prediction, the slicer preview and the finished print where available.
Titan poster
By vycdev. Artwork: NASA/JPL, Titan, Visions of the Future. 102.4 × 152.7 mm footprint.
  • Kromacut prediction: Auto-paint with the eight-color calibrated filament profile.
  • Slicer preview: Creality Hi, 0.4 mm nozzle and 0.08 mm layers. Slicer estimate: 2 h 58 min, 28.90 g including flushing and tower, six filament changes.
  • Finished print: Photographed by its maker. Lighting and camera processing can affect the colors shown.
Hope poster
By vycdev. 72 × 108.4 × 3.04 mm.
  • Kromacut prediction: Auto-paint prediction using the available calibrated filament profile.
  • Slicer preview: The physical layer plan prepared for printing without a red filament.
  • Finished print: Pale yellow matched most closely; red printed orange, cyan leaned purple-blue, and black reproduced the preview but missed the target’s dark teal.
Batman: The Jiro Kuwata Batmanga
By vycdev. Artwork: Jiro Kuwata / DC, Batman: The Jiro Kuwata Batmanga, Book 1. 65.8 × 100.0 mm footprint.
  • Kromacut prediction: Auto-paint with Deep optimization, enhanced matching, and Preserve color separation enabled.
  • Slicer preview: Creality Hi, 0.4 mm nozzle and 0.08 mm layers. Slicer estimate: 3 h 12 min, 21.30 g including flushing and tower, eight filament changes.
  • Finished print: The large title and silhouette remain distinct; small lettering and fine shading lose detail at this size.
Naruto
By vycdev. Artwork: Naruto. 110.4 × 190.2 mm footprint.
  • Kromacut prediction: Auto-paint with the eight-color calibrated filament profile, 0.15 mm pixels, and Smooth Meshing enabled.
  • Slicer preview: Creality Hi, 0.4 mm nozzle and 0.08 mm layers. Slicer estimate: 5 h 55 min, 72.10 g including flushing and tower, nine filament changes.
  • Finished print: The completed overnight print, photographed by its maker. Lighting and camera processing can affect the colors shown.
King of Hearts
By vycdev. 47.72 × 66.53 × 3.2 mm.
Hobbits and Dragons
By u/ominaex25.
The slicer estimates above count flushing and a prime tower for every filament change on a single-nozzle printer. That’s the overhead a toolchanger like the U1 cuts down.
How it works
  1. Load an image and reduce it to a small palette.
  2. Pick your filaments. Auto-paint plans the layer stack for each color using their Hiding Distance values and any calibration you’ve printed.
  3. Check the 3D preview and the printability warnings.
  4. Export STL or 3MF and follow the generated print instructions.
Update: Kromacut v4.3.0 is out
Kromacut v4.3.0 adds Multi-head printing, which covers most of the Phase 2 plan for the U1.
Release: Release Kromacut v4.3.0 · vycdev/Kromacut · GitHub
Changelog: Kromacut/CHANGELOG.md at main · vycdev/Kromacut · GitHub
Progress on the Phase 2 plan
  1. U1 export target: done. Multi-head builds export a 3MF with one slot per toolhead and every part pinned to its head. Kromacut sets the filament map to manual, so Orca keeps those assignments instead of reshuffling them to save flushing. Select the U1 printer profile in Snapmaker Orca before opening the file. The 3D panel lists the recommended settings for the build (wall loops, infill, layer heights).
  2. Toolchanger-aware planning: done for Auto-paint. Auto-paint now plans filament orders for 2–8 heads, so the U1’s four toolheads are covered. Each color region gets its own path through the filaments, filaments are assigned to heads so as few swaps as possible are needed, and a Head Schedule shows what to load before the print and at which layers to swap. Swaps become M600 pauses in the 3MF, so the print only stops when a head actually needs reloading. If a multi-head plan wouldn’t look noticeably better than a normal stack, Kromacut says so and keeps the single-head model. Flat Paint can’t be combined with multi-head yet; that’s the part still to do.
  3. Guide and validation: guide done, validation in progress. A new Multi-head printing guide in the in-app docs covers color runs and windows, the Head Schedule, color grouping and search depth, with four diagrams, in all 12 languages. If you try it on a U1, I’d love to see a photo of the print and hear whether the head assignments and reload layers matched the schedule.
Also in v4.3.0
  • Open in Slicer in the desktop app sends the 3MF straight to Bambu Studio, Orca Slicer, PrusaSlicer, UltiMaker Cura or the system’s default app, without a Save As dialog.
  • Undo and redo shortcuts for 2D edits, cancellable Auto-paint searches, clear errors for broken or oversized images, a 3D camera that no longer clips into the model, and safer desktop saves.
  • A new Awards page on kromacut.com with the Phase 1 Innovation Fund winner badge.
Next, before Dec 23
  • Flat Paint planning for multiple toolheads.
  • Validation prints on a U1, with photos and measured results.
