Four-U1 filaments can make far more than four colors: Lumina Studio
Hi everyone,
I would like to share Lumina Studio, a project I have been developing for multicolor 3D printed artwork.
The basic idea is to stack very thin layers of different filaments. Because light passes through these layers, the colors mix visually. This allows a relatively small set of materials to produce far more colors than the number of filaments loaded in the printer.
The U1 is particularly suitable for this. Four materials can remain loaded in four independent toolheads, so there is no need for an external material-changing system. With four materials and five printable color layers, there are theoretically 4^5 = 1,024 different stacking recipes.
This does not mean every recipe produces a visibly unique color, but after calibration it gives us a much larger usable palette than four flat filament colors.
If you attended RAPID + TCT in North America or TCT Asia in China earlier this year, you may already have seen some Lumina prints at the Snapmaker booth. I am curious whether anyone here remembers them. Those display pieces were made using the same layered color-stacking method.
How it works
The normal workflow is:
  1. Print a calibration board using the filaments you want to use.
  2. Photograph the board under controlled lighting.
  3. Use Lumina Studio’s calibration tool to measure the printed colors.
  4. Import an image or SVG into Lumina Studio.
  5. Match the source colors to the closest calibrated layer recipes.
  6. Export a multi-material 3MF.
  7. Open the 3MF in Snapmaker Orca, map the filaments, slice it and print it.
The printer firmware does not need to be modified.
For a first test, I strongly recommend using a simple SVG with clear color boundaries and only a few colors. It is much easier to understand the workflow this way. Photographs and detailed illustrations are possible, but they require better calibration and more adjustment.
Current versions
The public Lumina Layers 1.x version supports workflows using 2, 4, 6 or 8 materials. For the stock U1, the main workflow is four materials.
Lumina Studio 2.0 is currently under active development. It uses gradient calibration cards and a predictive color model instead of relying only on a fixed lookup table. It also supports a flexible number of materials, color layers and layer heights, with experiments currently reaching up to ten color layers.
The 2.0 source code is still in a private development repository. I plan to open-source it in October 2026 after the file format and calibration workflow are more stable.
Temporary online test
I am currently providing the development version free of charge for Snapmaker forum members to test.
Primary address:
http://online.luminastudio.com.cn:26712/
Alternate address, IPv6 only:
http://online1.luminastudio.com.cn:53278/
Online color calibration tool:
http://43.142.55.49:8765/
These are temporary testing servers with limited capacity. Please do not repost the addresses outside this forum for now.
The services currently use plain HTTP rather than HTTPS, so please do not upload private, sensitive or confidential images.
Bug reports, failed models and examples of unexpected color matching are especially useful. I am still improving the workflow and would like to know where new users get stuck.
Source code and documentation
Public repository:
Documentation and Wiki:
The public project is licensed under GPLv3. This is currently a personal, non-commercial project.
I would be interested to see what other U1 users make with it, especially unusual material combinations, translucent filaments, large-format work and objects that go beyond flat wall art.
This project is really interesting. See you in 9 hours.
Looking forward to your good news
So this is intending to be a paid for product in the future?
:pleading_face: :sob: No. The source code will remain open source permanently. We have simply added ways for people to support the project, including sponsor access to internal test builds, so that we can continue improving the software.
I funded the development out of my own pocket for a long time, but the ongoing costs eventually became difficult for me to sustain. Over time, that also wore down much of my motivation to keep working on the project.
No offense meant or slight against your work, it was just the wording (maybe English isn’t your primary language?)
Was more curious how this differs from Hueforge or the Bambu ripoff clone…
Yep,No offense taken. English is not my first language, so some of my earlier wording may not have expressed my point clearly. But to answer your question directly, Lumina is not simply another HueForge clone.
HueForge is a mature tool, but it mainly uses a height-based relief and global filament changes at selected Z heights. Lumina uses calibrated material stacks for different regions of the image and exports a true multi-material 3MF. On a printer such as the U1, multiple materials can be printed within the same physical layer, allowing neighboring regions to use completely different stacking recipes.
In terms of color reproduction, I believe Lumina can produce a more faithful result while using fewer filament colors. It measures a physical calibration board printed with the user’s actual materials, then selects combinations based on the colors those materials really produce rather than relying only on nominal values or a generic simulation.
If the comparison is with the “Bambu ripoff clone” you mentioned, then I will be blunt: in my opinion, Lumina decisively outperforms it. You can look at the results on my website or GitHub and compare them directly. The color accuracy, range and overall presentation are simply not in the same league.
Lumina is also much more than a single image-to-relief generator. It includes workflows for puzzles, keychains, fuse-bead patterns, large-format tiled prints, surface mapping onto 3D models and several other types of output. More features are still being developed.
Rather than writing another long explanation, I think the clearest comparison is to try it yourself. For a first test, I recommend using red, white, blue and yellow filaments. That combination makes the layered color-mixing effect very easy to see.
As a beta tester, I can clearly feel that the underlying principle of this project is much more flexible than HueForge. To give a simple example, HueForge was designed for the era of single-extruder printers, so when printing color-blended patterns, each layer uses only one color to reduce print time. However, this also results in one side of the finished product being uneven.
The multi-layer color-blending principle of this project allows different colors to appear on the same layer. In other words, the color in each smallest graphic area can be freely mixed using multiple extruders and various filament colors to create different color combinations. The final product’s color flexibility is greatly improved, as can be seen from the renderings.
Therefore, it is very suitable for use with independent multi-head printers (such as the U1), and it fully leverages the advantages of multi-head printers.
Lumina Studio really works—here are the results. However, the colors in the images are a bit off, so I decided to tone them down a bit and keep experimenting. I’ll show you the results a little later.
I used the deep red, deep blue, yellow, and white I currently have. Following Wiki’s recommendation, I immediately replaced the white in this set with “Jade White,” which has better light transmission. Here’s the result so far—it looks pretty perfect.
But in reality, the black on the figure has a reddish tint—it looks more like reddish-brown. So I took another shot with my mirrorless camera; this image actually comes closer to what I see with my own eyes.
Since the black didn’t render very well, I swapped the blue for black. I’ve also tried printing the next one. See you guys later!
First of all, it should be noted that this comparison is not for competition or to evaluate who is good or bad. It is only for reference. The one on the left was created by a community user using huefore, while the one on the right was generated by Lumina2.0. The user on the left has already adjusted it well, but there are still some deviations. However, the one on the right has been automatically processed and printed out The effect is very good.
@Fat_cat
Very interesting project - question from a Mac user - will there be a Mac version?
Yes. The current plan is to provide ready-to-install builds, including a macOS version, to project sponsors. The source code will remain open, so anyone can still build and run it themselves on macOS, Linux,docker, or Windows without sponsoring.
Thanks for such a detailed reply, I look forward to seeing this develop further!
(Mac user so can’t use yet)
Thank you! You do not need to wait for the macOS build. You can try the online test version directly in a browser on your Mac, with no installation required:
I recommend using Chrome for now. For your first test, try a simple SVG with red, white, blue and yellow filaments. Please let me know if you encounter any Mac-specific problems.
I tried the online version in Chrome on Mac. It gives me the below error message:
This site can’t provide a secure connection
online.luminastudio.com.cn sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
I got similar SSL error in Safari. Both browsers loaded the site well when I switched the URL from HTTPS to HTTP
HTTP is what it says in Fat_cat’s links.
Thanks for testing it on macOS and for reporting this.
CrazyIvan is correct: the current temporary test server is HTTP-only. HTTPS has not been configured for this endpoint yet, so opening the same address with https:// will produce ERR_SSL_PROTOCOL_ERROR. This is a server configuration issue, not a compatibility problem with Mac, Chrome, or Safari.
Please use the exact http:// address provided in the original post. I should have made the HTTP-only limitation more obvious, so I will update the post accordingly. I also plan to address HTTPS as part of the later public deployment.
I’m glad to hear that it loads correctly in both browsers over HTTP. Please let me know if you encounter any issues inside the application itself.
I think Safari really tries to use HTTPS instead of HTTP, which caused the URL issue. Then I copied the HTTPS URL from Safari over to Chrome, which is why I ran into the problem there too.
I tried the HTTP sites yesterday and I could load the page, load the image, set printer to U1 and adjust settings, but when both Mac/Chrome and Mac/Safari failed when I tried to preview or generate. It just sat there and spun for a real long time (20+ mins) then eventually failed.
I just tried Win/Chrome, Mac/Chrome and Mac/Safari none can load the site right now at all. On Win/Chrome I’m getting the below:
This page isn’t working
online.luminastudio.com.cn didn’t send any data.
ERR_EMPTY_RESPONSE
on Mac/Chrome I got ERR_CONNECTION_TIMED_OUT
Suggestions I have for the site design:
  1. when first loading maybe ask for a language. I used browser translation for a while before I realized that the site had localization.
  2. When I loaded my image the size of the print was still at the default (60x60?) but my image has a different aspect ratio. As soon as I tried to move the size slider, it corrected the other dimension to the right aspect ratio, but it should do that even if I don’t change the default size.
Thank you for the detailed report and for testing it across Windows, macOS, Chrome, and Safari. This helped me separate the browser behavior from the actual server problem.
I have confirmed that the IPv4 server is currently down. Therefore, the ERR_EMPTY_RESPONSE and ERR_CONNECTION_TIMED_OUT errors are on my side, not caused by your computer, browser, or network settings.
For now, please try the IPv6 test server:
This address also uses HTTP rather than HTTPS, so please enter the complete URL including http://. It requires your network to support IPv6. If it does not open, your current network may not have working IPv6 connectivity, in which case please wait until I restore the IPv4 server.
The preview/generation task taking more than 20 minutes was also abnormal. It may have happened while the backend service was already becoming unstable. I will inspect the processing service and task queue rather than asking you to repeat the same long test immediately.
I have also recorded both of your UI suggestions:
  1. The language selector is not obvious enough. I will make the language choice much clearer for first-time visitors.
  2. After an image is loaded, the print dimensions should immediately preserve its aspect ratio, even if the user never moves the size slider. I agree that the current behavior is incorrect and will fix it.
Once the IPv4 service is restored and the generation problem has been checked, I will post another update here. Thank you again for the careful testing and very specific feedback.
