Klicky probe - bed leveling on anything! Stealth mod for single extruder
I am not a 100% sure where to put that issue, or if I should open a new forum post.
I have built the dual extrude klicky probe as already stated and bed leveling seems to finally work now kind of as expected
  • Running 6x6 bed leveling with probe attached from the screen (because the G1029 Code is not applicable for the Dual Extruder)
  • Ripping the probe off before the auto z-offset of the dual extruder is done at the end of the z-offset cycle).
  • Then I still have to do an additional “Auto Z-Offset” from the screen and then I can print.
So far so good. The bed mesh is persisted but the Auto-Z-Offset value isnt. So i have to run Auto-Z-
Offset after every restart otherwise the printer starts printing in the air. Does anyone know how to fix that? Any G-Codes I don’t know? Happened on the 1.19 and on the newest vibration compensation firmware. (DUAL EXTRUDER)
In theory G1029 DXX, have a look here and please let us know if it works. Of course, did you save your offset by entering M500?
https://snapmaker.github.io/Documentation/gcode/G1029-abl
I did the bed leveling via touchscreen and then sent m500 but shouldt the z offset be saved anyways when I do it via the touchscreen?
From the wiki: In the current version, the operation of directly using the G1029 command is only applicable to Single Extrusion 3DP
Try to run the sensor calibration and afterwards one more bed leveling.
I thought you did the whole procedure over terminal.-Yes the screen should save the offset and level automatically.
