Installing Luban on raspberrypi4
Hi there,
Has anyone had any luck installing Luban on a raspberry pi? I’ve tried downloading all the versions off the SM website, but installing them is another issue.
The amd64.deb and the x86_64.rpm give me errors; probably because I’m running a 32-bit version (my best guess) and the x64.tar.gz doesn’t seem to have any install files that I can locate.
I’m running a raspberry pi 4 with 8GB of RAM and the raspberry pi OS (32-bit) a port of Debian Bullseye with the Raspberry Pi Desktop.
Any help would be appreciated.
amd64 version run on Intel or AMD processor.
Raspberry is equipped with an ARM processor (like the smartphones), so you need a special compilation of the code.
I do not know if that is existing presently.
Kind regards
If you plan to use it purely to control the snapmaker, Octoprint would be a better option. You can prepare files on your other PCs and send it wirelessly to the Pi and run through octoprint. If you’re wanting it for slicing and other things, Luban is a bit bloated for the Pi specs to begin with, and like @danucc mentioned, there’s no ARM version currently.
Great. Thanks for the explanations.
Old thread. Anyone get Luban running on a pi?
Tried to cross-compile it for RPi in a Debian ARM64 VM, virtualized on an ARM64 MacBook. Compilation works fine with minor tweaks to the process. Sadly it doesn’t run. I suspect it is not compatible with either the graphics driver (mesa?) or the window manager running on the RPi distro (RPi 3B+). It also doesn’t run in the VM, possibly also due to the graphics driver/software GPU.
Results may be better when compiled directly on the RPi but I haven’t tried yet.
Thank for the update.
