The enclosure is being used by the original.
I have upgraded the firmware.
However, the Z-axis does not move when using a 3D printer.
There is still a problem with the Z axis.
Does the problem disappear if I enter M1010 in the console window?
Or should I use it only for the laser module?
The problem must be solved.
Please. I need an accurate solution.
Thank you.
