Full Lightburn Control Guide
If you followed the guide fully, you can just send to the touchscreen via Luban and slam through the origin sequence and completely ignore it. While mine’s a 2.0 and not an artisan, I assume it should be very similar. I just have the manual thickness maxed out to shorten the time it takes to return to the home position. All the height and positioning information is in the gcode itself.
Little moki someone posted on discord. I really should play Ori and the will o the wisps. :slight_smile:
I would suggest going through my latest laser guide, it supersedes this one. While the title is for IR/40W, as long as you have your focal length, it should work for the 10W as well.
