Extrusion Calibration Issues
I am trying to complete the extrusion calibration, yet it seems no matter what I set the E value to the extrusion is a mimimum of 11 mm short.
I have ensured that prior to running GCode I set relative extrusion via M83. After each calibration I was initially using the equation E-value x 100(100-filament remaining after extrusion), though I noticed that after an initial reduction in the filament remaining, an increase in remaining filament was observed with an increasing E-Value.
To try and get an better idea of the relationship, I checked a range of ‘inbetween’ E-values and acquired the following results ( e-value (filament remaining after extrustion in mm))
200 (22), 212.21 (18), 220 (16), 230 (15), 238.44 (18), 250 (15) , 255 (12), 260 (11), 265 (11), 275 (11), 290.78 (12), 330.43 (18) , 402.96 (11).
I have check the hot end and it is clear. I have changed the nozzle to a new one (0.4 mm) prior to completing the above.
One point of interest, I note that with the lower e-values the filament extruded is 0.7 mm diameter, thought the higher e-values extrude a filmanent which is 1.0 mm in diameter.
I have ordered a new hot end on the off chance that this is the issue, though I am clutching at straws.
The current output from M503 is as follows:
others < G21 ; (mm)
others < M200 D3.00
others < M200 D0
others < M92 X400.00 Y400.00 Z400.00 B888.89 E255.00
others < M203 X120.00 Y120.00 Z40.00 E25.00
others < M201 X3000.00 Y3000.00 Z100.00 E10000.00
others < M204 P1000.00 R1000.00 T1000.00
others < M205 B20000.00 S0.00 T0.00 P0.05 L3.00 C0.05 J0.02
others < M206 X-15.50 Y-7.00 Z0.00
others < M420 S1 Z0.00
others < G29 W I0 J0 Z3.65625
others < G29 W I1 J0 Z3.62375
others < G29 W I2 J0 Z3.51750
others < G29 W I3 J0 Z3.37875
others < G29 W I4 J0 Z3.20125
others < G29 W I0 J1 Z3.81750
others < G29 W I1 J1 Z3.74375
others < G29 W I2 J1 Z3.62000
others < G29 W I3 J1 Z3.49250
others < G29 W I4 J1 Z3.34625
others < G29 W I0 J2 Z3.92875
others < G29 W I1 J2 Z3.86375
others < G29 W I2 J2 Z3.70000
others < G29 W I3 J2 Z3.58375
others < G29 W I4 J2 Z3.41375
others < G29 W I0 J3 Z3.99375
others < G29 W I1 J3 Z3.91125
others < G29 W I2 J3 Z3.78125
others < G29 W I3 J3 Z3.63625
others < G29 W I4 J3 Z3.49250
others < G29 W I0 J4 Z3.97625
others < G29 W I1 J4 Z3.91625
others < G29 W I2 J4 Z3.76875
others < G29 W I3 J4 Z3.67000
others < G29 W I4 J4 Z3.52250
others < M301 P13.00 I0.10 D17.00
others < M851 Z1.00
others < M900 K0.04
If anyone can offer advice on how I can improve the extrusion calibration it will be very much appreciated.
Many thanks
Dan
Sounds like you’re extruding too fast. Slow it down.
Thanks Brent. I’m not sure how to do this - but I shall scour Google and figure it out.
I brought some new filament and the printouts using the eSun filament are much better than the SnapMaker filament, I am not sure if this would have made any difference though?
Regards
Dan
