Hello its been a while since i was active here. I mainly used the SM for CNC and Laser bc I allways had problems with the print quality.
Yesterday i needed to print something big on the SM otherwise i had to split the model!
Now the Problem is that on some spots the printer is underextruding but the esteps are calibrated. On the other side the print stringed a lot the print temp. was not the problem i print allways with the same filament and i set the retract to 0,6mm with 60mm/s
Are there some new ways or things to calibrate?
Im happy with every help
Currently running a print with these settings in Cura, and it looks good so far:
Things I changed from default:
minimum travel: I do not want retraction too often - I accept a bit of stringing, since retration sometimes makes things worse in other aspects. So I changed to 5 mm, sometimes even more.
extra prime amount: To compensate for oozing during travel. Went higher earlier, but that then caused overextrusion at the start of print after travel. N.b.: Cura uses volume (mm³) - most other slicers use length (mm). In Prusa Slicer I use 0.2 mm.
Maximum count: The small extruder gear of SM2 with its sharp teeth quickly gnaws through the filament - the default of 90 is flirting with desaster!
Z-Hop: Never yet used it, but people say it reduces likelihood of knocking over large prints. May be worth switching on.
Ok you are using the default retraction and this is good? I tought for a direct drive extruder it is too much but i will test it thanks. The extra prime could be a success
As I understand it, retraction goes like this: print - retract X mm - travel - push in again by X mm plus extra prime amount - continue to print. So, in an ideal world, the retraction distance should not really matter. Aside from that retract/push in by X mm takes longer the larger X is. But we talk about fractions of a second. Of course in a long print, it adds up, so you’re right in that sense.
So with 5mm retract and the extra prime amount it looked a lot better! I will also slow down the print speed a little bit and it should also gibe a improvement. But lot of stringing was going on
