Anyone know where to find additional workpiece clamps for the Artisan laser bed?
use 2020 aluminum extrusion profile corner brackets or im looking into getting ok vise clamp pieces.
these might be the exact bolt size im spacing on the size, this is what im probably gonna grab
print it yourself ![]()
LaserClamp.stl (35.4 KB)
That will work for the plastic tabs but not for the screws which I assume are nylon. I don’t have a convenient way to verify the treads. I assume something like M5 coarse.
The laser bed threads are for M6 coarse Nylon screws. Thread pitch is 1mm.
Has anyone found an STL for a clamp that matches the stock clamps. The one linked above isn’t an exact match. M6x16mm nylon thumbscrews (the size of the stock thumbscrews) are readily available from Amazon. If nothing else, the clamp would be easy enough to design for 3D printing, but I hate to reinvent the wheel.
