- Version: v4.2.2
- Laser workspace A Text object is created in Edit and the text, font and size are edited. The Text object is then copied. The copied Text objects do not retain the changes when in the Process tab.
- Expect the copied Text objects to have the same attributes as the original Text object.
- Operating System: Windows 10 x64
- Printer: Snapmaker A350 (probably all)
I didn’t repeat this problem, can you provide a project that contains this error?
fc7667a2.docx (18.5 KB)
Hi
I had to change the file extension to upload, wouldn’t accept .snaplzr
The text at the top was the original object, which I edited.
I duplicated this text object and moved it to the lower part of workspace.
Selected both and created toolpath
Generated gcode and the font is not retained in the duplicated object
Hope that helps.
Alan
We have confirmed the problem, thanks
