Is there a way to set up a roughing pass in the CNC module for 3 axis or 4 axis with the rotary in Luban? I don’t see anything the the rotary module 4 axis. It would be great to be able to do a pass removing most of the material with a flat endmill, and then do another detail pass to clean and finish it.
Unfortunately Luban doesn’t support clearing passes and there has been no indication given from SM that this is even in the works.
If you want this functionality you’ll need to use a different cam program like Fusion 360.
Unfortunately for 4th axis work that means you’ll have to pay for it.
