CNC and CUT | Label for Baseball Caps
Hello out there, I hope to find someone who can help me with some CNC and cutting advice! Thanks
Maybe you should just pose the question…
Trying to do CNC and also cutting like the example attached. I appreciate sny support!
What have you tried? If you haven’t tried anything yet I’d suggest you start by reading the quick start guide, do the example project, and start practicing on cheap scraps.
Can you help me with the M600 command which is not working with me
M600 is filament change when printing. Has nothing to do with cnc.
If you don’t share what you are doing (setup, configuration, gcode etc) nobody will be able to help you. (or feel like helping for that matter)
I know aorry about confusing. Trying to generate GCode with filament change but machine doesnt recognize it and just cntinues printing without atopping for change
Update to the latest Firmware.
