This is what it shows when you issue the command in terminal.
You can convert it to Z offset by ticking the relative Z box.
I am still learning on it but I think it is well worth knowing the information.
My problem is the plugin will never show an mesh, its only showing:
What version of Octopi are you running? Other plugins that might interfere?
I only installed mine a few days ago, so pretty vanilla install and up to date. (and using the Octopi image, no custom install)
I run the latest, and a few addons:
The debuglog of BV reportet:
[2021-01-03 19:06:31,309] DEBUG: mesh collection started
[2021-01-03 19:06:31,381] DEBUG: resetting mesh to blank because of CATMULL subdivision
Whats the heck…
This is my output of M420V
Send: M420V
Recv: Bilinear Leveling Grid:
Recv: 0 1 2
Recv: 0 +14.049 +14.516 +15.146
Recv: 1 +13.991 +14.577 +15.236
Recv: 2 +13.987 +14.555 +15.264
Recv:
Recv: Subdivided with CATMULL ROM Leveling Grid:
Recv: 0 1 2 3 4 5 6
Recv: 0 +14.04875 +14.19856 +14.34838 +14.51625 +14.71421 +14.93023 +15.14625
Recv: 1 +14.02759 +14.19363 +14.35966 +14.53977 +14.74332 +14.96094 +15.17857
Recv: 2 +14.00643 +14.18869 +14.37095 +14.56329 +14.77243 +14.99165 +15.21088
Recv: 3 +13.99125 +14.18398 +14.37671 +14.57750 +14.79171 +15.01398 +15.23625
Recv: 4 +13.98602 +14.17965 +14.37328 +14.57620 +14.79462 +15.02233 +15.25005
Recv: 5 +13.98676 +14.17554 +14.36432 +14.56560 +14.78771 +15.02230 +15.25690
Recv: 6 +13.98750 +14.17144 +14.35537 +14.55500 +14.78079 +15.02227 +15.26375
Recv:
Recv: leveling ON
Recv: echo:Bed Leveling ON
Recv: echo:Fade Height OFF
Recv: ok
I am nearly going insane of that addon
Can’t test right now, but the only obvious difference I notice immediately is that you’re running the 3x3 leveling while I am using the 5x5 pattern.
(and wow, still such a big difference with a glass plate…)
@brvdboss what do you mean, the level of my glassplate? its only a travel in the right way, but still bad.
How to set 5x5 in “cellphone” its 5x5?
is there anything after this output somthing thats called CATMULL
To set the calibration grid on the touch panel:
The output I get when executing M420V is (yest still a bad leveling, still not properly mounted, just wanted to test):
Send: M420V
Recv: 0 1 2 3 4
Recv: 0 +8.274 +8.334 +8.246 +8.202 +8.147
Recv: 1 +8.482 +8.601 +8.581 +8.600 +8.600
Recv: 2 +8.526 +8.686 +8.675 +8.791 +8.799
Recv: 3 +8.426 +8.641 +8.709 +8.829 +8.866
Recv: 4 +8.255 +8.457 +8.644 +8.752 +8.891
Recv:
Recv: 0 1 2 3 4 5 6 7 8 9 10 11 12
Recv: 0 +8.27375 +8.29921 +8.32467 +8.33375 +8.31389 +8.27763 +8.24625 +8.22884 +8.21629 +8.20250 +8.18500 +8.16625 +8.14750
Recv: 1 +8.34944 +8.38148 +8.41352 +8.42967 +8.41790 +8.39023 +8.36685 +8.35631 +8.35007 +8.34264 +8.33179 +8.31976 +8.30773
Recv: 2 +8.42514 +8.46376 +8.50238 +8.52560 +8.52191 +8.50282 +8.48745 +8.48379 +8.48384 +8.48277 +8.47859 +8.47327 +8.46796
Recv: 3 +8.48250 +8.52722 +8.57194 +8.60125 +8.60342 +8.59018 +8.58125 +8.58532 +8.59370 +8.60000 +8.60139 +8.60069 +8.60000
Recv: 4 +8.51463 +8.56456 +8.61449 +8.64791 +8.65132 +8.63821 +8.63259 +8.64671 +8.66832 +8.68472 +8.68992 +8.68991 +8.68990
Recv: 5 +8.52842 +8.58309 +8.63775 +8.67430 +8.67671 +8.66100 +8.65713 +8.68215 +8.71902 +8.74652 +8.75447 +8.75304 +8.75162
Recv: 6 +8.52625 +8.58592 +8.64560 +8.68625 +8.69046 +8.67565 +8.67500 +8.70833 +8.75583 +8.79125 +8.80180 +8.80027 +8.79875
Recv: 7 +8.50620 +8.57249 +8.63878 +8.68602 +8.69717 +8.68928 +8.69435 +8.73151 +8.78164 +8.81935 +8.83203 +8.83228 +8.83254
Recv: 8 +8.47018 +8.54336 +8.61654 +8.67134 +8.69225 +8.69477 +8.70703 +8.74543 +8.79356 +8.83037 +8.84505 +8.84840 +8.85176
Recv: 9 +8.42625 +8.50338 +8.58051 +8.64125 +8.67273 +8.68782 +8.70875 +8.74791 +8.79291 +8.82875 +8.84736 +8.85680 +8.86625
Recv: 10 +8.37444 +8.45052 +8.52660 +8.59027 +8.63277 +8.66284 +8.69439 +8.73444 +8.77595 +8.81176 +8.83755 +8.85764 +8.87773
Recv: 11 +8.31472 +8.38681 +8.45890 +8.52389 +8.57821 +8.62543 +8.66907 +8.70953 +8.74642 +8.78213 +8.81704 +8.85076 +8.88449
Recv: 12 +8.25500 +8.32310 +8.39120 +8.45750 +8.52365 +8.58801 +8.64375 +8.68463 +8.71689 +8.75250 +8.79653 +8.84388 +8.89125
Recv:
Recv: leveling OFF
Recv: echo:Bed Leveling OFF
Recv: ok
edit:
I just tried it with the 3x3 grid and it actually still works for me.
I think I will buy my a rope!
this is exactly what I am getting too! But the damned thing wont work.
By the way, the “cellphone” has set the 5x5, but BedV… only did a 3x3!
So the question again: is this code as yours?
M420 V ;get data
G1029 A :leveling
G1029 S ;save data
G1029 D0 ;end leveling
M420 V ;get recent data
G28
and this setting too:
please tell me there is any difference beside the debug logging! PLEASE
I just have the M420V command in there (I only used it to visualize so far)
But now I have been able to reproduce your problem
I messed up the calibration on purpose to make sure the orientation of the graph and bed was as I expected and put a piece of metal underneath it (to make sure I could see a spike of 1cm in the graph And now it’s also waiting infinitely.
I’ll keep doing some more experiments.
I have always been running calibration from the touch screen btw
What shi…is going on?
I did the calibration from the “cellphone” too, thats the only thing I use it for.
This is the intention getting this thing to work!
BTW: Thanks for your help!
Hello brent, can you share a bit of your skill to me?
Where are the G commands like 1026 1029 … are documented
or can you expand my knoledge in this direction?
They are not documented officially
I usually reference either the source code G1029 or @Tone’s post here: How to do a larger than 3 x 3 matrix level
whats a shame, think they shoud!
But thanks for the hint
Ok, at least one “bug” so far in the bed level visualizer. If the measured value is above 10 (or something in that neighborhood at least), I get the endless loading screen.
So this:
Send: M420 V
Recv: 0 1 2
Recv: 0 +17.042 +17.024 +17.056
Recv: 1 +17.405 +17.510 +17.776
Recv: 2 +17.014 +17.409 +17.840
Recv:
Recv: 0 1 2 3 4 5 6
Recv: 0 +17.04250 +17.03435 +17.02620 +17.02375 +17.03079 +17.04352 +17.05625
Recv: 1 +17.19125 +17.19312 +17.19499 +17.20760 +17.23809 +17.27932 +17.32056
Recv: 2 +17.34000 +17.35189 +17.36377 +17.39144 +17.44539 +17.51513 +17.58486
Recv: 3 +17.40500 +17.43403 +17.46306 +17.51000 +17.58681 +17.68153 +17.77625
Recv: 4 +17.33042 +17.38846 +17.44650 +17.51977 +17.61840 +17.73226 +17.84611
Recv: 5 +17.17208 +17.26627 +17.36045 +17.46426 +17.58411 +17.71358 +17.84305
Recv: 6 +17.01375 +17.14407 +17.27440 +17.40875 +17.54981 +17.69491 +17.84000
Recv:
Recv: leveling ON
Recv: ok
results in the endless loading loop and this:
Send: M420V
Recv: 0 1 2
Recv: 0 +8.490 +8.435 +8.379
Recv: 1 +8.736 +8.875 +8.989
Recv: 2 +8.491 +8.839 +9.108
Recv:
Recv: 0 1 2 3 4 5 6
Recv: 0 +8.49000 +8.47171 +8.45342 +8.43500 +8.41634 +8.39755 +8.37875
Recv: 1 +8.59028 +8.59359 +8.59689 +8.59931 +8.60023 +8.60025 +8.60028
Recv: 2 +8.69055 +8.71546 +8.74036 +8.76361 +8.78411 +8.80296 +8.82181
Recv: 3 +8.73625 +8.78343 +8.83060 +8.87500 +8.91477 +8.95176 +8.98875
Recv: 4 +8.69097 +8.76155 +8.83213 +8.89819 +8.95672 +9.01072 +9.06472
Recv: 5 +8.59111 +8.68578 +8.78044 +8.86847 +8.94544 +9.01578 +9.08611
Recv: 6 +8.49125 +8.61000 +8.72875 +8.83875 +8.93417 +9.02083 +9.10750
Recv:
Recv: leveling ON
Recv: ok
just works.
(yes, I followed the printhead around with a piece of metal to get that first measurement )
So that points to a bug in the bed level visualizer (didn’t go looking in the code yet). Even though I have the graph Z-limit set to 20 in the config.
I noticed that in one of your previous posts you had values >15 so that might be the reason why you’re getting the infinite loading screen.
edit: the magic number seems to be 10, this one doesn’t work anymore either:
Send: M420V
Recv: 0 1 2
Recv: 0 +8.490 +8.419 +10.171
Recv: 1 +8.739 +8.872 +10.865
Recv: 2 +8.502 +8.851 +9.120
Recv:
Recv: 0 1 2 3 4 5 6
Recv: 0 +8.49000 +8.39870 +8.30741 +8.41875 +8.86782 +9.51954 +10.17125
Recv: 1 +8.59088 +8.51910 +8.44732 +8.58759 +9.08130 +9.78706 +10.49282
Recv: 2 +8.69176 +8.63949 +8.58722 +8.75643 +9.29477 +10.05458 +10.81440
Recv: 3 +8.73875 +8.71449 +8.69023 +8.87250 +9.39898 +10.13199 +10.86500
Recv: 4 +8.69593 +8.71383 +8.73173 +8.90060 +9.32108 +9.89253 +10.46398
Recv: 5 +8.59921 +8.66777 +8.73633 +8.87593 +9.13392 +9.46295 +9.79199
Recv: 6 +8.50250 +8.62171 +8.74093 +8.85125 +8.94676 +9.03338 +9.12000
Recv:
Recv: leveling ON
Recv: ok
edit2:
So I assume there is some regular expression parsing the data that expects only one digit before the decimal point. But my python isn’t great so can’t put my finger on it yet. (And I hate programming languages that use whitespace as a part of the language…) It would have helped if it was somewhat documented in code as well.
Will you file the bug at bedlevelvisualizer?
Yes I will do it thanks so long!
Ok,
it seems to be line 44 in this file:
https://github.com/jneilliii/OctoPrint-BedLevelVisualizer/blob/master/octoprint_bedlevelvisualizer/__init__.py
in particular this part:
(\s*\[\s+)|(\[?\s?\+?-?\d?\.\d+\]?\s*,?)
which should need to be:
(\s*\[\s+)|(\[?\s?\+?-?\d+?\.\d+\]?\s*,?)
(the added +
after the first d)
if I’m correct.
and this regex validator seems to confirm this:
Don’t know if it has any impact on the rest of the code. but would hope not.
I did the same with a bit of plastic and the 0,0 corner is correct. I thought originally I had to flip but not the correct setting is with none ticked.
@brvdboss HiHi just found the hearts for likes, you are unbelivibel!
what do you mean?
