Change location of purge/prime line when printing single color?
Greetings, I’ve noticed that The purge(prime?) line tends to print in a pretty inconvenient location whenever I print in a single color.
Particularly with PETG I think that particular spot doesn’t get hot enough, so the petg won’t stick to it well. (also its around where i might grab the plate after the print is complete, thus might get finger oiled)
Is it possible to move it more inwards? (maybe inwards by like 10-15mm)
Towards the right or left would also be nice, but not necessary.
(All I could find was a guide to remove the line completely)
Thank you!
(ps: I’m using a non-snapmaker plate in the image. but the behavior of the purge line not sticking well is the same on both the stock-snapmaker plate and aftermarket plate)
Suggest to check in the Discord channel where there is a discussion about this- moving the purge line to the back of the plate. check here please - you need to amend the start code in Snorca. Snapmaker Official
thanks for the link! the information there helped me find out which part of the gcode to edit/how.
on a funny note if you edit this highlight text from “1” to like 5(or what ever value u want) it makes it more inwards
Indeed. X and Y are the horizontal axis and Z is the vertial one. X is the one from left to right and v.v. - and Y the one back and forth. X1Y1 describes the front left position then.
Why is that a “funny note”? It’s a statement of fact. I have similarly moved the wipe line on other printers.
