Hello, I need to manually control the rotation of a workpiece that is mounted on a rotating module. In all settings, it is possible to control only the spindle or laser - but it was not possible to make the rotary module rotate. Is there any solution?
You may need to slide left on the jog screen. Not at the bottom, but in the control area. The rotary module jog control is on “screen 2” you might say…
EDIT: Sorry missed that you asked for Artisan - what I write is true for Snapmaker 2.0 - perhaps it’s the same with Artisan?
There in “control” - just available CNC or LASER manual control. Same with Luban from PC.
