Advance Mode Snapmaker Artisan
Any one have clue about this Artisan print screen, came from https://wiki.snapmaker.com/en/snapmaker_artisan/troubleshooting/limit_switch_unable_to_trigger probably bad picture selected when wiki created but look like to be interesting.
Turn On
Special privileges after enabling
  • After enabling this option, you will be allowed to modify the printer configuration files.
    Before you fully understand the function of the printer configuration options, we strongly recommend that you do not modify them.
    Arbitrary changes may cause abnormal operation of the device, such as temperature protection, XYZ calibration, heated bed leveling, and automatic feeding functions.
  • Advanced mode allows you to add and modify the machine’s configuration files at will, which may lead to potential problems, for example: print job failures or damage to the printer equipment.
[ ] Agree
I asked in the mod group, let’s see if I get answers..
This screenshot is from U1 printer interface. Wiki article is fixed now.
Sad!!! will be great to have access to more advance stuff on artisan
