A350 Service for linear moduls neccessary?
Is it neccessary to make service for he linear moduls ?
i.e. to grease the internal studding ? with graphite for example. -or to clean it ?
For the Ultimaker 3 I’m using too there is a tube with grease included and they point out, you should use it every now and then.
K.D.
The grease is a PAO. I wouldn’t use graphite. There’s a link at the bottom to a DOW PAO on amazon, something like that would be OK. Lubrication should not be necessary regularly.
