This drawing is awesome and will come in handy. My A350 bed is so distorted on 2 corners that I can’t print any item larger than about 175 mm x 200 mm. Since my printer is out of the warranty period, it would be nice if I can use the full capability of the machine. I’m sure I’m not the only person with this problem. The original cast aluminum bed is not very stable after repeated heating & cooling cycles.
I’m in desperate need for a new, level bed so I can print a large electronics case for a custom 3D printer I’m building. I plan on machining a new bed from aluminum mold plate because it’s more stable at higher temperatures and resists thermal stress & deformation.
Does anyone here know what the maximum allowable weight of the print bed is on an A350?. Ideally I’d like to eliminate some of the open spaces in the bed and make it more solid but also know the weight will be a factor in loading the steppers as the bed travels during use. Any bed weight specs & stepper loading info from the Snapmaker Design Team would be helpful and very much appreciated.
Thank you in advance for you input.
