I’m currently building a custom mechanical keyboard and need a silicone dampener(5mm). I did cast it from silicone and need to laser cut the keyboard layout.
I played around a bit but couldn’t get good results e.g. silicone starts heavily warping during laser pass.
Did anyone already cut silicone before and can you give me some recommendations?
What settings do you use?
I would guess going as fast as possible but with multiple passes would be a good approach - If you have a air assist or a fan you can direct to the material you properly can improve the result even more
