Rainbow Spectrum (aka Full Spectrum 2.0) — Optical Color Blending for the Snapmaker U1
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
Alpha_Studio
Project name
Project URL
Project cover
Project Category
Software
Project Summary
I designed and implemented Rainbow Spectrum from scratch in Rainbow Orca Slicer for the Snapmaker U1. Pick a target color, and the slicer suggests recipes using the filaments already in your setup.
I DESIGNED AND IMPLEMENTED RAINBOW SPECTRUM ENTIRELY FROM SCRATCH. IT IS A NEW OPTICAL COLOR-BLENDING METHOD DEVELOPED INDEPENDENTLY OF RATDOUX’S FULL SPECTRUM.
Rainbow Orca Slicer builds on OrcaSlicer (GitHub - OrcaSlicer/OrcaSlicer: G-code generator for 3D printers (Bambu, Prusa, Voron, VzBot, RatRig, Creality, etc.) · GitHub). I developed Rainbow Spectrum’s optical wall model, recipe search, painting workflow, and perimeter generation from scratch. My additions to the fork also include Rainbow16 filament-slot painting and SnapScreen integration, automatic filament-change optimization, SpiderVein supports, and the material-aware perforated wipe tower.
A thin, translucent outer perimeter lets the filament behind it influence the visible color. Rainbow Spectrum evaluates combinations of filaments and outer-perimeter widths, then shows the closest predicted shades. You can paint with a recipe like a regular filament color. During slicing, Rainbow Orca turns it into perimeters with the specified materials and widths. The sliced test cube shows the internal filament paths behind three large painted dots.
Set a slot color from a published filament swatch or measure a sample from your spool with an AS7341-enabled SnapScreen build. SnapScreen illuminates the sample, reads reflected light in several spectral bands, and estimates an RGB color that you can sync to Rainbow Orca. For both input methods, Rainbow Spectrum estimates Transmission Distance from FilamentColors.xyz reference samples. The cover is a conceptual render. The GitHub screenshots show the actual slicer and generated toolpaths.
Additional Rainbow Orca features
• Rainbow16 model painting assigns colors to physical slots across the U1’s four toolheads. My separate SnapScreen project integrates with Creality’s CFS family and coordinates filament changes using stock U1 firmware. Other controllers can use the same slot inventory and G-code requests.
THE LIMIT OF 16 APPLIES TO THE PHYSICAL FILAMENTS SUPPLIED BY THE AUTOMATIC FEEDERS. IT DOES NOT LIMIT RAINBOW SPECTRUM TO 16 COLOR COMBINATIONS.
• Filament-change optimization plans filament use across layers. It minimizes physical reloads first, then toolhead changes among equally good reload counts. The example preview reports 286 toolhead changes and 328 filament changes.
• SpiderVein / VWS uses cross-braced branches designed to improve stability and use less support material.
• The Rainbow16 Classic wipe tower uses staggered perimeter gaps and one structural wall material type from base to top. Incompatible filaments are purged inside the tower.
The public repository contains the source, build instructions, and eight captioned screenshots.
I do not consent to other developers using any part of my work in their submissions to this competition. I ask other entrants to respect that request. The code is published under AGPL-3.0, and the license continues to govern its reuse.
Open Source Status
Open Source
Please specify the open source license used by this project
GNU Affero General Public License v3.0 (AGPL-3.0)
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Original New Idea
If based on an existing project — your independent contribution
N/A
Is it a paid project?
No
Rainbow Spectrum and Rainbow Orca Slicer — screenshots
SnapScreen discovery. Rainbow Orca finds SnapScreen on the local network while configuring a Moonraker connection for the Snapmaker U1.
Physical filament inventory. Rainbow Orca displays filament slots grouped by toolhead, with the color and material profile for each slot. Slots 9–16 are visible here.
Physical filaments and Rainbow Spectrum recipes. The painting tool shows 16 numbered physical filament slots alongside five Rainbow Spectrum recipes. Each recipe can be selected as a paint color.
Painted color test. A test cube carries color patches across three faces, with the Rainbow Spectrum recipes visible in the sidebar.
Rainbow Spectrum color blending in the sliced preview. This job uses all 16 filaments loaded across four Creality CFS units. The cutaway shows how Rainbow Spectrum arranges different filaments within the walls of three large painted dots to create their blended shades.
Perforated wipe tower with a material-compatible outer wall. The preview shows staggered gaps in the outer perimeter. Rainbow Orca selects one structural material type for the wall and uses matching filaments from base to top so successive layers bond reliably. Incompatible materials are purged inside the tower.
SpiderVein / VWS supports. Cross-braced branches support a wide overhang on a T-shaped test model. The preview reports estimated support material separately.
Automatic filament-change optimization. The sliced job shows 286 toolhead changes and 328 filament changes. Rainbow Orca automatically plans the order across layers to minimize physical filament reloads while meeting the job’s material requirements.
