Directory management under Mainsail works, but Fluid does not perform management very well.
Can someone (in plain English) explain how to get Mainsail on the U1?
Why have you posted this in Snapmaker 2.0? I’ll move it…
It’s actually quite simple: check the IP address on the U1’s display and enter it in your PC’s browser. This will take you to Klipper, where you can easily manage your uploaded files. All without needing extra firmware. ![]()
I understood most of what you posted in the video.
Great job… but
When you modified the ‘.cfg’ files, you selected ‘machine’ on mainsail
My problem is, I can’t see how to open the cfg (without Mainsail) to delete the hashtag of fluid.
Thanks
Barry
There is a gui for making the change from Fluidd to Mainsail as well as some other options. Look in the Paxx12 firmware docs for the gui url.
