Are there any firmware limitations to this? (I’ve only ever used Paxx12 firmware and plain Orca Slicer, so not familiar with the stock firmware/Snorca)
Yes, the link seems to indicate that the option for multiple nozzle sizes is built into standard Orca since 2.2.0 beta. They recommend making the profile “nozzle agnostic” by setting line width in percentages in relation to the actual nozzle size.
I’m not real experienced with 3d printing or the U1, so was just curious if anyone had successfully done this, or if I’m missing anything. But the lack of responses here maybe means it hasn’t been tested much, if at all. I might just need to make the leap! We’ll see
It’s a very new thing, only recently enabled in the U1 firmware and not yet supported in SnOrca, so…
So I wonder why the desire to fiddle with this. Using multiple nozzle diameters in one print is niche to say the least, an optimisation for when you’ve run out of other optimisations. Unless you’re doing production printing, hobbyists make one-offs – and spending hours perfecting the slicing is never recovered in the printing time.
Fair enough . Probably a little of the motivation behind it. But not really. I enjoy some experimentation, but generally if it’s moving toward something that’s potentially useful.
I realize there would be extra calibration required if, e.g., a 0.6 nozzle is added to the mix, but I could also see even a hobbyist “standard” set-up on the U1 being three 0.4 nozzles plus one 0.6. You put your primary filament on the 0.6 for a bit more speed. Or the 0.6 is hardened steel for abrasives. Or you have two 0.6 and two 0.4. Some options. It might lead to a “regular” set-up that allows for more variety/speed/strength options with less frequent changing out of toolheads or nozzles. Doesn’t seem to be that odd or niche of a discussion to have. Especially with both Snapmaker and Orca Slicer making some movement in that direction, it may well indicate community interest in the feature.
All in all, though, to each their own, and appreciate the input.
I could also see a use case where you use a larger diameter nozzle for your support materials so you can print those at a larger layer height than would be possible with a small one. For example using 0.4mm for your print, but 0.6 for supports at a 0.3-0.4 layer height. Or going the other way and doing most of a domed print with a larger nozzle, but switching to the smaller one for finer layer heights on the last few layers to eliminate as many layer lines as possible.
Someone on Discord developed a piece of software that even supports different nozzles and layer heights, but I couldn’t get it to work properly after downloading it.
Multiple layer widths has been done, but I don’t believe multiple layer heights has yet. ForcaSlicer recognizes that as a limitation here. Although ForcaSlicer says they’re working on it, so fingers crossed.
I think the concept is cool, and as it matures, we may well find it to be a practical improvement. It’s great that ForcaSlicer is diving into it as a specific topic. Right now, though, it’s hard to say with layer height being limited to smallest nozzle, max flow apparently somewhat limited to smallest nozzle, additional calibrations and settings needed, etc, whether this would be worthwhile at this point.
Unfortunately, I’ve had some issues with my Pika 0.6 nozzle hotend, so I haven’t been able to test a multi-nozzle-size print yet. I’d say it’s worth pursuing, though, to see what comes of it.
It’s very doable and has been done. Fur support, you can choose the interface z gap. When it’s not 0, that line has a different layer height than other lines in the same band. A band in Orca coding is all the lines/region at the same Z position. There are some other forks of Orca providing mixed layer height solutions, but from what I’ve seen so far, they are all based on synced Z band. Not saying it’s bad, not at all. If you actually mix 4 sizes of nozzles, and 0.8 nozzle prints once for every 3 times 0.2 nozzle prints, it’s probably give you a good enough result in terms of quality and speed. What I am working on is to break the bond of Z band. It works in most cases, but needs some tuning for some extreme situations.
I do not like Orca’s percentage solution on line width with mixed nozzles. 0.8 nozzle should print 0.82 line width and 0.2 nozzle 0.22 line width most of the type according to snapmaker shipped presets. A 105% setting on them is wrong. 105% is based on 0.4 nozzle printing 0.42 line width. On 0.2 nozzle, 0.21 line width is probably fine, but first layer 125% on 0.8 nozzle is 1.0 wide vs 0.82 wide, that’s a big difference. That’s why in for fork of Snapmaker Orca, I have line with at absolute mm values, and with per nozzle line width and speed, you can see those values update as you change nozzle diameters.
Thanks for the additional clarification. Hope you can pull it off!
There probably would be some people ready to test what you have. Unfortunately, I don’t have a working 0.6 nozzle right now, but should have one soon.
Will also be interesting to work on whether additional work will be needed on calibrating filaments for the different nozzle sizes, potential different process settings, etc
In my roadmap, mixed layer height isn’t limited to mixed nozzle sizes. If you are printing a cone, and you can print wall at 0.12 but infill, top and bottom at 0.28 with 0.4 nozzles, there are benefits.
No point of creating a new post for the same question. Any official news from Snapmaker on them supporting multi size nozzles across the print heads on the same print? is this something they are even working on for us?
The machine itself already supports multiple nozzle sizes and if you slice in plain Orca Slicer you can already use multiple nozzle sizes in the same print (with some of the caveats/settings listed above). I’ve done a couple prints on the U1 w one .6 and one .4 in plain Orca Slicer.
