The Orca thing should already be there. The current version is based on OrcaSlicer 2.3.1 stable build. Of course there’s already a couple fixes in the Nightly build for OS.
I think I need to set something in Fluidd for the camera, which I tried, but I never had any luck getting Fluidd to show me a camera anyway on any printer.
I still can’t find anything abut the timelapse, it looks like I need to install Moonraker, I’d rather not do any custom firmware / installs like that at this time though.
Lets revive this post. This is something that has been annoying me since I got my U1. I’ve been looking at the config files and you can add the following to your printer.cfg file
initial_duration: 30.0
gcode:
SET_LED LED=cavity_led WHITE=1.0
you can play around with the value for initial_duration , but 30s works for me
if you are on PAXX you can add it to the custom.cfg in /extended/kipper folder ( if you don’t have one you can create one )
[delayed_gcode TurnOnLed]
gcode:
