Laser Studio — A Dedicated Laser Engraving Workspace, from One Piece to a Whole Series
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
Alpha_Studio
Project name
Laser Studio
Project URL
Project cover
Project Category
Software
Project Summary
I am developing Laser Studio, an independent laser engraving application for Windows and Linux. It brings design, image preparation, toolpath previews and guided production into one workspace.
The project began with the Hanboost T1/T1 Pro and a practical question: how can a small engraving area support larger layouts and small production runs? Users start with one table, add others in any direction, and arrange separate letters, artwork or repeated items. The workflow includes confirmation steps for repositioning the machine or replacing a workpiece between tables. This is intended for separate motifs, not seamless stitching across manually repositioned areas. A 3D-printable positioning base is planned.
The prototype includes live text editing, custom TTF/OTF fonts, multi-selection, grouping, rotation, alignment, smart guides, raster/vector import, grayscale power-modulation preparation, dithering, optional local VTracer tracing with a preview, CSV personalization, toolpath previews and table-order simulation. Optional Cloudflare Workers AI generation uses the user’s own account. English, German and Polish are supported.
I have prepared an experimental Snapmaker Artisan Premium 40W profile and a separate SACP communication path. I do not own an Artisan, so this integration is not physically verified. I am requesting an Artisan Premium to test communication, coordinates, work origins, positioning, file transfer, power/speed commands and interruption behavior, then document and fix the results. The current Artisan workflow uses prepared-file transfer and manual start on the touchscreen.
The first public prototype is available as Windows Setup, Linux AppImage and DEB packages. During release preparation, 799 automated tests passed, alongside isolated packaged startup checks on Windows and Linux. These do not certify physical engraving. Following recent changes, engraving and work-area positioning require renewed hardware tests; not every function is guaranteed. Functional testing comes first, with visual polish continuing during and after testing. Source is private; downloads are free.
I already own a Snapmaker U1, along with several other 3D printers, so another standalone 3D printer would not address this project’s needs. An Artisan Premium would provide the missing hardware to continue development and work toward reliable, documented compatibility on a real machine.
One last hint: Laser Studio is a standalone Windows/Linux application, with mobile support planned, but it is also already a full engraving workspace module inside FreedomSlicer. FreedomSlicer is my next big reveal, and I plan to submit it to the Innovation Fund soon. I am saving that surprise for its own introduction.
Open Source Status
Closed Source
Please specify the open source license used by this project
N/A — original application code is proprietary; third-party components retain their respective licenses. Public prototype downloads are free.
Cash Fund or U1 Hardware Sponsorship
Originality
Original New Idea
If based on an existing project — your independent contribution
N/A — Laser Studio is my independently developed application. Third-party libraries are used as dependencies and retain their licenses. The experimental Snapmaker integration was informed by publicly available protocol and manufacturer references; it is not a claim of verified hardware compatibility.
Is it a paid project?
No
A closer look at Laser Studio
Here are a few screenshots from the current public prototype. These are real application views using demonstration projects, not photographs of engraved results. Physical engraving and work-area positioning still need validation after the recent changes; Artisan compatibility remains experimental.
1. From a single table to a larger layout
I designed Laser Studio to start with one engraving table and expand only when needed. This example shows six separate nameplate designs across six 55 × 55 mm areas. The idea is to prepare independent letters, motifs or items as one project, rather than stitch a continuous image across manually repositioned borders.
2. Arrange tables and prepare repeated work
The arrangement view separates table planning from object editing. I can add a neighboring table in any direction and optionally copy its contents for batch preparation. Each table has its own thumbnail and position, making a larger job easier to review.
3. Inspect generated toolpaths
After generating paths, I can review the engraving geometry and travel moves before exporting or working with a device. This screenshot shows actual generated outline paths across the six-table project. The displayed speed, power and time estimate are demonstration settings, not tested material recommendations.
4. Rehearse the table sequence offline
The table simulation lets me walk through the order of the job and the placement confirmations without connecting to a machine. It distinguishes the current table from those still waiting. This is an offline rehearsal, not evidence of completed engraving or verified physical positioning.
5. Prepare raster artwork locally
The image editor shows the source/crop and processed preview side by side. Brightness, contrast, gamma, sharpening, resolution and grayscale power mapping can be adjusted before applying the result. The preview shows how the software prepares the image; actual tones and detail depend on the material, focus, machine and validated settings.
The Windows and Linux prototype downloads, updates and testing notes are available here:
Thanks for sharing with us. So is this project more for Artisan Premium sponsorship?
Yes. I know this contest is related to the U1, but I thought I’d post it here to ask for support for Artisan. The program has enormous potential, which I’m testing on a Hanboost T1, which is more of a toy than a real device. I’d like it to support Artisan, as the Freedom Slicer launches in a few days, and this program will be one of the modules. And Freedom Slicer will be a revolution in the slicing market.
I thought it had a chance of getting noticed thanks to the competition and it would somehow be possible to put it together.
