IP address changes without any input from me
My router (firewalla purple on 192.168.1.1) has a static IP assignment for the U1 at .56. In the last hour the printer has been on .39 and .40 as well as .56. The change happens during printing, never when idle. I have no idea why it’s doing this.
Is .56 within your router’s DHCP pool – ie the range of addresses it is allowed to hand out for general DHCP? I can’t verify this, but it might help if the address you have allocated is outside the pool, because if another device has already been allocated that address, the router can’t re-allocate it.
The U1 would only be making new DHCP requests if it lost connection with the network, so are you sure your WiFi is stable and good strength? Nonetheless, the router ought to spot the same MAC and hand out the same address.
This is another situation where having manual control over networking parameters on the U1’s control panel would help. See Manual Control of LAN IP Address
I have set the MAC address of the printer to be bound to an IP address. This is set in my router. I suggest you try that as it’s the most stable option. (assuming you didn’t bind it to the MAC address specifically).
I did mention that my router has a fixed IP assignment for this device.
56 is inside the pool.
Right now I seem to have masked the problem by running a neverending ping on .56 which prevents the router from expiring the lease due to inactivity. I run in LAN mode only, so no keepalives to the mother ship.
$l=@(Get-Content $env:TEMP\u1ping.log); $f=@($l -match ‘False’) $max=0;$run=0; foreach($x in $l){ if($x -match ‘False’){$run++;if($run -gt $max){$max=$run}} else {$run=0} } “{0} samples, {1} lost ({2:P2}), longest consecutive run {3}” -f $l.Count,$f.Count,($f.Count/$l.Count),$max
But you didn’t mention if you used the MAC address to fix the IP. That’s why I explained. The question is, did you do it via the MAC address?
that ping masking it’s a big tell, lease might be dropping mid-print. fingers crossed keeping the static ip out of the pool holds
How could it be made static at the router without binding it to the MAC?
Good question. I just didn’t want to assume. But I guess the issue lies with the router anyway. It should basically be impossible for the IP to change if it’s fixed to the MAC address.
Just an idea: have you tried rebooting the router?
Yes
K1FZY (WA4TPW) SK 9/29/37-4/13/15
That was my understanding. The printer does not seem to be using randomized macs
Yup. This problem has been running since my U1 arrived.
I have both my printers assigned a static ip address done in the router’s dhcp table. The addresses are assigned to the MAC address on the printer.
Even if their isn’t a static ip assigned the printer shouldn’t be changing ip addresses while it’s printing, it would be renewing the existing lease.
I think your routers DHCP server might have an issue of some kind. I would check & see if there are any firmware updates for your router. Rebooting might also correct the problem.
Still investigating, and I agree.
late to the party but have to agree with others that it must be the router causing the issue as the printer will use the IP address its told to
Even more strange that its doing this in LAN mode though? How old (roughly) is your router & how far away from the printer is it?
The Firewalla is a few years old, latest firmware update was applied a few weeks ago. The distance is about 15 feet with a clear line of sight to the WAP, and the WAP connects to the firewalla through a hardwired switch.
Hi, just an idea.
If you connect via both LAN and WiFi, the U1 has two MAC addresses.
At least that’s the case for me, so I had to reserve both of them in the router.
When I set the WiFi address as the primary access point in Fluid, I noticed that it would occasionally switch over to the LAN connection.
I don’t have any lan connection on the U1.
