IP address changes without any input from me
When we say LAN mode when referring to the U1, it means the U1 is connected to the local network only & not using the cloud. The U1 the WiFi only not hardwired connection.
I am in LAN mode, using wifi. I know some are using USB to ethernet adapters. Not practical for me,
Try to set fix IP address which is not inside your DHCP.
I run my printer with a fixed IP on LAN mode and have the same IP since day 1 :slight_smile:
