Fusion 360 allows not multiple depths?!
Hello there,
so i wanted to make a 2D design and carve it out with the SM2. But doing a carve with 3mm in one go would end in a destroyed miling bit. So why is there no multiple depths option anymore? or is laser cutting the better way? its the frosted acryl platte that you can buy in the SM Shop. But the normal lasermodul is to weak for 3mm thickness is it?
I only cnc acrylic when using clear. Otherwise I use the laser to the snapmaker black acrylic with ease (10W). 1600mW laser would take many, many passes, and likely end up with a not so nice edge.
yes thats why i need to use cnc for this. But i dont get it why the multi passes option is gone
