Findings and solution for the Snapmaker J1 clogging problem
Never posted it here. The combo I used was:
  1. CNC Kitchen Volcano Adapter v3, 8.5 mm length
  2. Titanium/copper (?) M6 tube, MK8 hotend bimetal heatbreak. No name brand bought on Amazon that’s now out of stock
  3. Bondtech CHT coated brass MK8 nozzles
  4. Some Noctua NT-H2 thermal paste for the threads
I recall it was tricky getting the orientation of the heat block correct while also getting the right depth into the block.
I also recall I didn’t tighten/heat the block properly. Came back to find the left nozzle was oozing from the top once while printing, but caught it in time to not be a big, big mess.
Also the reminder to check the electrical continuity to Pin 1 of the PCB to the nozzle tip before installing. That was good advice. One of them didn’t the first time I assembled it. Start over…
Anyways. These nozzles eliminated frequent, minor skips and clogs at any random layer while printing PLA when many other suggested fixes didn’t. Every once in a while, I instead found I would sometimes get a hard clog during the first layer of a print.
This was new. I can’t confirm this solved it, but I then started preheating the bed. Theory being it was due to the bed and hotend starting at the same time by default start gcode, but the bed takes much longer.
(Also later changed the start gcode to wait for bed before firing the hotend in case I forget. Usually I remotely heat the bed while I’m slicing. )
Now I think I haven’t really seen this first layer clog happen again.
I did not do any flow testing since I don’t really think the kinematics are good above 175 mm/s without getting a shift every once in a rare while. The Y gantry isn’t light.
Lastly, the updated Snapmaker, all-metal hotends came out a few months later and I switched to those. These were provided freely to me as an affected person when they did the community outreach about it.
In terms of performance (other than flow which I’ve not tested), they’ve performed identically to the ones I made as far as I can tell. Including a first layer clog when I didn’t preheat the bed, and no skips while printing. So I’ve just kept using those since they’re also hardened.
Cheers!
