Camera feed in Fluid Interface
I ran into the same issue. I wanted the stock U1 camera to actually display as a live feed in Fluidd rather than downloading the snapshot, so I ended up building a small MJPEG bridge that runs directly on the U1.
It uses the stock Snapmaker camera service, requires no external computer or custom camera firmware, starts automatically after reboot, and I’ve tested the install/recovery process on my U1.
UPDATE: v1.0.1 is now available and is the recommended release. It adds automatic recovery if the U1 stock camera monitoring session stops updating. See the v1.0.1 update below for hardware test results.
I posted the project and instructions here:
GitHub:
Hopefully this solves the issue you were running into.
