Cameras in Fluidd, Firmware 2.0.0
I’m investigating the camera issue with standard firmware, and it looks to me like any camera support has been removed from Fluidd. No sub-panel shows up for cameras, and when I go into the layout setup and delete every panel except cameras, the Fluidd window is empty. See screenshots below.
Am I interpreting this correctly? (Answer: no – see next post)
Default Fluidd configuration:
Change the configuration (three dots, top right > adjust dashboard layout):
Dashboard with only Cameras panel enabled:
No, I’m not!
The Cameras panel shows up when you add a camera in settings (cogwheel icon, down the left).
The problem I am trying to address is why the built-in camera shows up in SnOrca (the Device panel) but not in Fluidd. I wouldn’t put it past me to have fiddled with something to cause it (and forgotten)!
Here’s the Fluidd setup screen for a new camera, default entries:
Anybody know the appropriate settings? The default ones don’t work!
I have tried to use Wireshark to see the traffic from SnOrca, but I’m using a USB Wi-Fi dongle on my Linux machine and it is proving difficult to snoop the traffic.
OK, found this: Camera feed in Fluid Interface - #9 by ni42
That got it!
I switched to Ethernet temporarily, and got some Wireshark data of SnOrca accessing the camera, but I can’t make much sense of it. Might be using encrypted protocols.
Yesterday it was working, today it isn’t.
I’ve tried disabling and then re-enabling the camera in Settings, to no effect.
weird one, did the stream url in fluidd still match snorca’s? could’ve rotated after a reboot or something lol
Since the latest 2.x firmware, Fluidd is doing the same thing for me: Internal (error)
This used to work! I just noticed it not working. I’m not sure when it stopped work.
Is anyone looking into this, or know of a fix without adding 3rd party changes?
An interesting thing I just noticed!
If use the Snapmaker app and turn on the camera, then the camera display works in Fluidd!
I don’t remember it needing this in the past.
Further tests show that after some time the camera in Fluidd stops working unless the Snapmaker app is opened again, and then enables the camera view.
How can we get Snapmaker to fix this in the firmware? Fluidd is a built-in tool and should work without any additional third-party software, and without needing to use the Snapmaker app on my phone!
Even with Paxx firmware, the camera view in Fluidd freezes every now and then and has to be restarted. I’m not a software guy so I can’t explain what the technical problem is.
However, I am very much of the opinion that if “third-party software” fixes the problem it’s foolish not to use it. Why U1ers Shouldn't Be Scared Of Custom Firmware
As a long term (now retired) firmware and software engineer, I’d rather Snapmaker engineering fix root bugs and problems! Especially in core built in features, such as Fluidd and the OEM camera.
Then they/we can leave adding extra features and enhancements to third party developers.
I’m not afraid to use third party enhancements!
But this issue is a problem with the OEM implementation, and is certainly not out of ordinary and expected use of the U1.
