Downloads and Updates for Firmware
Feb. 1, 2019: Snapmaker-GD32Base-2.8
Thank you for your suggestions to make the Snapmaker better. Here comes the latest version of the firmware. Your feedback is always appreciated. Please post bug reports and feedback to this topic: Bug Reports and Feedback for Snapmaker-GD32Base-2.X =)
Change Log:
  1. Fixed the bug that Z axis/Y axis can’t Home correctly by moving the Y axis back 2mm after hitting the limit switch.
  2. Fixed the bug that the 3D printing module landed outside of the heated bed when calibrating.
  3. Fixed the bug that the Z axis would hit the top when the slider is close to the top and it’s homing.
  4. Fixed the bug that the laser may burn the material when jogging the module or running boundary at 6% power. (M3 Sxxx. Wrong conversion from S to percentage(%).)
Download:
Snapmaker-GD32Base-2.8.zip (76.0 KB)
Note:
  1. Only products that come with the USB Disk can upgrade the firmware.
  2. You can check the About page for the firmware version after the upgrade.
